Question about General Electric Refrigerators
I have a GE side by side frig model #GSS201ETA that freexes up about every 3 weeks, the coils inside at the back of the freezer end up solid ice, i have to pull it apart and thaw it with a hair dryer and we're good for another 3 weeks - what gives?
huuum
  • 750 Answers
SOURCE: Side by Side Maytag Frig/Freezer Frig not cooling
Hello momeddy41,
I'm Huuum to your rescue.
Is your freezer packed to the top, and covering any air ducts near the back of the freezer?
The freezer and fridge share the air and if the circulation from the freezer to the fridge is cut off ,
this could cause problems.
Or you may just need a shot of coolant to raise the pressure in the coil.
It's not necessarily wise to spend a lot of money on an old fridge over 7 years old.
But*** it's better to try one service call and find out if it is one of the many simple things first, as I showed you. Then you would ne saving the price of a new fridge for awhile!
That's your call.
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give me a rating before you sign off!
Bless You, Thank You, HUUUM
Posted on Sep 22, 2008
docjohn174
  • 943 Answers
SOURCE: Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Posted on Oct 14, 2008
MNTECH
  • 1543 Answers
SOURCE: GE MDL:TBX25ZLB Top Freezer Refrigerator Freezes up
You need either a WR51X314 defrost heater, or more likely a WR9X413 defrost control (defrost timer) for your TBX25ZLB. Unfortunately, these part are listed as "No Longer Available". Next time you want to defrost it, find the defrost control at the back of the refrigerator section, very near the temperture set knob (the one that goes from 1-9). You will most likely have to pull the knob off and remove the cover to find the visible part of the defrost control timer. It is a round flat looking plastic part, usually black or white, smaller than a dime, with a groove in it which you can turn with a flat blade screw driver. Turn it slowly clockwise (they usually make a clicking noise as you turn them) until it makes a rather loud click. Now if the refrig was running, it will stop and turn on the defrost heater. If the heater is good, it should begin to glow red and heat until the frost melts or the timer advances back to the run position (usually about 30 minutes). (if there is lots of build up on the freezer, it will most likely take longer than 30 minutes of defrost heater operation to melt it all. You can help it with your hair blower, if you think you need to. ) All this will help to eliminate the defrost heater itself as the problem. A larger parts store may have a defrost control timer left in inventory, or be able to suggest a generic defrost control which you can use. In the mean time, you can defrost your refrig manually this way once a week or so for 45 minutes, then manually advance the timer again to the run position. (If the defrost control timer is bad, it usually will not advance itself back into run) Send a comment with how things turned out or if you have any other questions. Please don't rate this, as anything but a Fix-Ya lowers my score.
Posted on Feb 05, 2009
2coolrick
  • 560 Answers
SOURCE: G.E. side by side Freezer Coils and back wall full of ice.
If you replaced the "defrost timer", and the circulation fan runs ok before the ice buildup occurs, you will have to melt the ice so the panel will come off. Then, pull the back panel off and inspect to components. First, the defrost element and connections to it. If connections are good, disconnect 1 connector and check the resistance of the element itself with a ohmmeter. It should be 40-150 ohms, depending on the unit. If it is excessive or infinate, replace the element. If it is ok, leave the element disconnected and check the other component (defrost termination switch) which is clamped onto the evaporator coil and has two wires attached to it. It should read 0 to 2 ohms at room temprature, and no more than that as it is a temprature controlled switch. If it has excessive resistance, replace it. These are the only 2 components, aside from the defrost timer, that encompass the entire defrost circuit in most refrigerators.
Posted on Jul 31, 2009
aasc
  • 1606 Answers
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
Ge side by side not cool enough even on higher settings
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE GSS20IEP Side by Side Refrigerator
Freeze will not freeze.
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator, model TFX26KRDA, serial LZ245571. For the past few weeks I have noticed an ice buildup on the back panel of my freezer section. Also the freezer isn't super cold and...
while you have the freezer panel out look at the defrost heaters to see if they are burnt up, there may be 2 heaters on a GE they look like glass tubes with a spring running through them on e at the very bottom and another about halfway up. a good heater will be faily clear a bad heater will look greyish and burnt on the inside. this is most common issue for ge defrost problems. if both heaters look ok. need to check the defrost sensor its mounted to the top of the coil it will have an orange and I think brown wire going to it it is a round disc looking piece. not sure if you have a multimeter if you do check it on ohms and yo should read infinity as long as the sensor is still frozen.
now if both of those check good then only thing left is bad defrost control which means replacing the motherboard loated on the back of your refrig.
shoot me a message if you have anymore questions.. thx peyton
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
107 people viewed this question
Top General Electric Refrigerators Experts
Van Allen II
Van Allen II
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
