Question about Garden
Chain saw wont start husqvarna 262 xp - Garden
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. Make sure to have fresh fuel/oil mix (50:1 ratio) in the tank. Be sure to premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Remove the spark plug and check for blue and snappy spark. If ok, try pouring a little fuel mix into the plug hole and try for start. If it pops, then you have fuel problems--try cleaning and re-kitting the carburetor. Pay particular attention to the diaphragm in the lower chamber--it should be flexible with no holes or cracks. Does the primer bulb pull fuel into it when pumped several times? Hope some of this helps!
Posted on Nov 07, 2010
I have a husqvarna 375xp chainsaw and I can't find any information on this chainsaw. Can someone please tell me how and where to find the information.
would say limited production edition
if its age is around 2013 they company started a new production plant
possible something in the carby tweeked ,longer bar ?
is it painted something other than orange ?
husqvarna didnt change their saws designs radically
even the chains and bars from most husqvarnas will fit
this user manual will cover your chain saw
365 SPECIAL 372 XP 372 XPG
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_EUenAPen/HUSO2010_EUenAPen__1153180-26.pdf
May 06, 2016 | Husqvarna Garden
Won't start when motor is warm. Saw for half hour and shut it off and it refuses to start again
this sure sounds as if it's an overheating problem , this causes the ign ckt to over heat and shut off the spark at the plug , id get a real good look at the cooling fins and make double sure theres no sawdust or other stuff in there blocking up the works , if you continue to run saw to overheat eventually it will damage the ign ckt to the point it wont come back on and saw wont run ,Period.
I use strong compressed air to blow out stuff stuck down in the ribs of saws(wear glasses )
Aug 06, 2015 | Husqvarna 550 XP 50.1cc 16 in. Autotune...
Magnito clearence
Hi Stanley, 8 thou is the correct gap. regards Phil.
Aug 25, 2012 | Electrolux 10pk / Husqvarna 55 372 395 455...
How to adjust oiler on husqvarna 266
Your saw didn't get a hit, she long of tooth?
Husky 262 manual
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1998/HOUS1998_1018843-26.pdf
The adlustment is on page 31. It is probably similar. HTH
Lou
Oct 04, 2009 | Husqvarna Chain Saw 20" Bar
262 XP engine cut out on tickover, now will not start
Try checking for spark when she won't start. I'll wager your ignition module quits when it gets good and warm. HTH
Lou
Sep 28, 2009 | Husqvarna Garden
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna small chain saw won't stay on and now won't start
check your pick up coil . i had one it done the same thing to and that what it was
Apr 02, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
857 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
