Question about Singer 2662
Hello I have the same problem with my 2662 and all the other different stitches too. I'm just able to do the straight stitches.What's wrong with this model?
    Genius:
  • 1,788 Answers
What do you have your width set for? How wide do you want to go? Read your manual and you will see the problem. If, by chance, it still does not work, call Singer at 1-800-4singer
Posted on Nov 10, 2010
  • hend7179 Nov 10, 2010
    Hey Tks for your reply. I've tried every setting you can imagine, exactly as described in the manual and different width too. Yesterday I've tried again and none of them work, just straight stitches. Is very sad since I've used this machine so little, and now that I start sewing a little more this is happen. In another web site they said Singer knows about this problem so, I wrote them, let's see what their answer is going to be.I'll keep you posted
  • Mary Dunn Nov 10, 2010
    I think that you should call them because that is not right to have to put up with that problem. If, that is a defect they should stand behind it and give you a credit to buy a different machine or fix this problem, once and for all for you and for free. Don't wait for the mail reply. Bombard them email, phone and your letter by post office.
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Will only make straight stitches
do you have a manual for the machine?
Apr 27, 2012 | Singer 2662
I have a singer 2662. How do I set up machine for basting?
i have a singer melody 40 and need the to no what numbers to set my machine at for straight stitch
Nov 03, 2011 | Singer 2662
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Jan 13, 2010 | Singer 2662
Machine will not stitch
It is either a top or bottom tension problem. Top tension speaks for itself. Most folks do not know that there is the facility on the bobbin case to alter the bottom tension. Your user manual will tell you how to do this. It is very difficult to describe how to do it you need diagrams or to be shown
Mar 25, 2008 | Singer 2662
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Sewing machine straight stitch is not straight
It sounds like it is making a blind stitch, does it look something like this? -----v-----v-----v-----v-----v If so it might be on the blind stitch setting instead of the straight stitch! ;-)
Oct 11, 2007 | Sewing Machines
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Skipped stitches, but only certain spots
Maybe wrong kind of needle; universal usually works for all, but not always, ball point for knits and sharp for woven.
Oct 09, 2006 | Singer 2662
Singer 2662 Logo
249 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
