Question about RCA Televison & Video
My picture seems to be too big. A feww weeks ago my grandson go hold of the remote and I think somehow he did something and ever since then the picture seems to have zoomed forward.
  • dldbell Nov 07, 2010
    Thanks for the quick responce. I think I'd better set things straight...my TV is about 20 or so years old. Therefore it's not a flat screen. I tried everything you said to do and nothing worked. Any more suggestions???
    I asked for your help 4 hrs. ago. I tried the solution you offered and it didn't work. I think I'd better tell you about my TV. It's an RCA Home Theatre. It's about 20 or so years old. It's a Model F27701BK.The seriel no. is 433530016. Can we try again???
    President:
  • RCA Master
  • 749 Answers
There is a button on your remote that does exactly that - zooms in.
It should be called "ZOOM" or "FORMAT".
It has several possible combinations.
If you have universal remote chances are the button might not be available there.
In this case you will find it in the TV's menu, in the PICTURE settings. It will be called "ZOOM" or "PICTURE FORMAT" or just "FORMAT".
Available options can be different from manufacturer to manufacturer, but almost all will have "Normal" or "Standard", then 4:3, 16:9 etc.
Once you find it you should easily choose the "Normal" one.
Posted on Nov 08, 2010
  • RCA Master
  • 736 Answers
There is a button on the remote that adjusts picture size. The button differs from brand to brand.
First before checking the button on the television remote please check the cable television remote. Look on it for a button hdzoom# format or aspect. You press that button to adjust picture size. Each time you press it it should give you a different option.
If your cable/satellite was attached to the television in two places the television might be on the wrong input. The television should be on the input for hd programming and not on the tuner input. For example when the television is turned on and you see the display info box it should not say 03 or 3.0.
Back to the button on the television remote it will say view mode, wide, format, aspect or something of that nature. Pressing it will give you different picture size choices.
Also if your cable box is set to the wrong resolution somehow this can happen. The cable box should be set to 1080i or 720p depending upon what your television can broadcast.
Posted on Nov 07, 2010
I believe my ignition is wired wrong on my grandson's 2001 Chevrolet cavalier. My grandson wired in a speaker control and I think he has connected something incorrectly. it tries to start even with the...
It always helps to state eng size and trans. He has power going to the start wire...somehow. If its a A/T its a yellow wire, M/T purple. check the wires he has messed with.
Nov 30, 2010 | 2001 Chevrolet Cavalier
Grandson has ps3 for over a year, 2 weeks ago, he cant play any games until he pays licensing fee, 29.95, i pd the fee, now 2 weeks later he cant play again till he pays the same fee. i think he is doing...
I have never heard of needing to pay any kind of fee to play games on the PS3. Is the fee needed to play the game offline or only to play online with others, because I've only heard of a fee to buy games off of the Playstation store, and that is a one-time payment
Aug 25, 2010 | Video Game Consoles & Games
I have a big black square on the screen. My grandson had the remote and I think it has something to do with pip but I can't figure it out.
He turned on the Closed Caption Text Mode. Just go into your menu to the closed caption section and turn it back off. It might be under the audio section also.
Feb 04, 2010 | Toshiba 42H81 42" Rear Projection...
I have a Samsung series 5 530 and the picture only recently is too big for the screen. also tried everything in the manual. Just started a few weeks ago.
The picture size may have been changed on the remote. Try the button that says pic size or something close to that. It must have been switched to a mode which zooms in the picture. That should fix it.
Jan 11, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Picture on screen is to big
Picture zoom may have been activated. Try MENU on remote and select "Picture" and look for "Normal", Zoom1", "Zoom2", "4:3", etc. Select normal or auto and exit.
Good luck
Techjoel
May 13, 2009 | Panasonic PT-50LC13 50" Rear Projection...
ROSS 1 way remote control
1. Switch on the television
2. Hold down the mute key and red light starts blinking
3. Continue holding down the mute key while pointing the remote on the television
4. Once red light stops blinking try switching television off by pressing the red turn off key
Tested and method worked on Ferguson tv
Mar 25, 2009 | Televison & Video
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
