Question about Casio Exilim EX-Z77 Digital Camera
I dropped my casio exilim 7.2 mega pixels digital camera EX-Z77 while the lens was out. The lens does not appear to be bent or damaged but reports a lens error and will not turn on and the lens will not go all the way in. What do I do?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
I have a casio exilim Z77 camera. It fell in the sand at the beach and ever scince is giving a blurred view. i gave it to the casio dealors here but they say some part of the camera has been damaged and...
i want help you but the casio say right to you. the proble is that the sand is go into the lens block.. you can make this.. if you have a friend that have a little eletronic knowledge.... its possible to find the entire lens...on ebay international seller... write on ebay.
lcd casio ex z77
look here on this link
http://cgi.ebay.it/GENUINE-CASIO-EXILIM-EX-Z77-GOOD-LENS-FOR-PARTS-/180536724405?cmd=ViewItem&pt=Digital_Camera_Accessories&hash=item2a08d3cbb5
you have ont his link the lens for your camera the cost is 36 us dollars complet with shipment... so if you look now on you tube and write..
(casio objektiv umtauchen) you can see exactly how you have to do to replace your lens. i am sorry that i am italian if you was here i can help you better, but i hope to have help you sorry for my bad english
Jul 10, 2010 | Casio Exilim EX-Z77 Digital Camera
MY EX-Z77 CAMERA SAYS LENS ERROR. HOW CAN I FIX THIS
what happen if my exilim camera lense is stuck in the camera
Jun 08, 2010 | Casio Exilim EX-Z77 Digital Camera
How do I fix the lens Error on my Casio EX-z77 ?
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2010 | Casio Exilim EX-Z77 Digital Camera
Casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Jul 05, 2009 | Casio Exilim EX-Z77 Digital Camera
Lens Error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | Casio Exilim EX-Z77 Digital Camera
LENS ERROR
then it's time to take it in for a repair estimate.
Apr 24, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
"Lens Error" on Exilim Casio 8.1 mega pixels EX-z9
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 22, 2008 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio exilim Z77 optical lens error
The warranty isn't going to cover if you drop it so you would have to pay for the charge. You can bin it if you like. That is your choice.
Jun 09, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
422 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
