Do you have this circuit board (RJBX0688AA) Model # SA-AKX10 Serial # /N SERIE LROFB004750
Fuse locations on Technics SA-DX930
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
May 14, 2008 | Technics SA-DX930 Receiver
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
Como saber el modelo de mi laptop toshiba
English Translation:
Greetings: I have a satellite laptop and I am trying to check the sticker where it leaves the model and serial number but not visualize anything, but through it I got the serial number through command and has thrown me sgte result 1C157182Q and I get the exact model and to find the drivers for the laptop ...
Toshiba Laptops have the serial and model information on the bottom of the laptop. IF you do not see it on the bottom you will have to remove the panels on the bottom as sometimes they put this information on the inside of the panels.
Hope this helps.
-FlukeLSX
Portatiles Toshiba tienen la informacion de serie y modelo en la parte inferior de la portatil. SI usted no lo ve en la parte inferior, tendra que quitar los paneles en la parte inferior ya que a veces ponen esta informacion en el interior de los paneles.
Espero que esto ayude.
-FlukeLSX
Sep 25, 2013 | Toshiba Computers & Internet
Problem with Technics SA-DX850
SA-DX750 (sister Model to SA-DX850). Showing error code F70, after a few minutes running. Checking the power rails revealed +5VA and +5VD, on the Digital Circuit Board 'A', dropping to about 2V, when fault occured. F5, T1A, on the Sub-Transformer Circuit 'M', was subject to occasional blowing. The problem was traced to an intermittent break, in the printed circuit board conductor, in the vicinity of Q1702 (+5VD regulator) collector, on the Digital Circuit Board 'A'.. Repairing this cured the problem. Note that removing F5 (above), or disconnecting CN702, CN1000A or CN904B, on the Digital Circuit board 'A', also causes this error code to be displayed. Failure of the audio output ICs, IC651 & IC801, is apparently the usual reason for this error code being dsiplayed, but it is worth checking the power rails viz. +/- 25V (Fuses F3 & F4, T6.3A, on Sub-Transformer Circuit 'M') +/- 55V, +/- 14V etc.
Aug 11, 2009 | Technics SA-DX850 Receiver
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
TMu220 serie 25 for usb
Hi
option 1 - buy a pci parallel card
option2 - buy a cable serial 25 to usb the cost is $30 dlls
Oct 26, 2008 | Epson TM-U220 Matrix Printer
Receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Mar 03, 2008 | Technics SA-AX710
298 people viewed this question
 Grubhead
Grubhead
