Question about Kenmore Dryers
We have an he front load dryer, and all of a sudden there is no heat when turned on. what should i check or look for
First (if it is 220 volt heating) check the breaker. some breakers for 220 V has two toggle switches.
one switch could be on and the machine would run, but no heat. reset both switches and try again.
It could be the heating element or a thermosat. and not very likely it could be the timer.
With a gas dryer. check thermostat, burner coils, heat senor, and ignitor.
hope it helps
Posted on Nov 07, 2010
I have a front loading large capacity kenmore dryer about 6 yrs old. All of a sudden it has stopped heating. To Heatman from Hartman
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 31, 2010 | Dryers
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Will not turn on!
Some dryers have an auto off switch when the belt breaks. Check your belt and pulley in the bottom of the dryer
Sep 06, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
Whirlpool awg 338 washer
initially check the element for continuity then check that any part of the wiring has not come off. if the water does not heat up it may not be advancing the timer to continue with the later stages of the wash, ie waiting for the stats to say the water is warm enough. tone.
Jun 04, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Dryer not heating up
Hi Mally Try the following thread - http://www.fixya.com/problems-solutions/t103658,p117053/Bosch-Dryers.aspx It might also be relevant to your problem. Another pointer - - There might be a heat-sensitive fuse in the exhaust section of the dryer. The fuse is designed to turn off the heater element if the exhaust temperature gets too high. If this fuse is defective, it will keep the heater element from getting current. Good luck!
Jun 22, 2006 | Candy CNW156 Front Load Washer / Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
