Question about Epson Stylus R380 InkJet Photo Printer
My EPson Stylus Photo R380 will not work, on the display screen, it says X Error in red. Printer error Please your documentation. Says turn off. I can not do anything, press all buttons, does nothing. Started when I hit print, a paper got jammed, I pulled it out and now can't get past this messgae. Unplugged printer from wall, from computer, from wall. Do not have documentation.
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
SOURCE: How do I change the ink cartridges for the the
hi,
first you remove the cartridge properly as shown in the manual, or in help content,
and insert new cartridge in printer properly.
by
ajay
9881233275
Posted on Feb 18, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
paand
  • 147 Answers
SOURCE: I have an Epson stylus
You have to open the casing in order to remove the paper.
Posted on Jul 10, 2009
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
Colors on screen do not match colors in print have an SyncMaster 204b screen and an Epson Stylus Photo R380
You will have to keep collabrating the colors on your monitor until you get the right print out. If you're not using the right ink this will also throw off the print outs. Epson R380 is not really your avg high end printers so you will not get the best results. I suggest look for a monitor collabration software to correct your problem.
Nov 13, 2009 | Epson Stylus® Photo R380 InkJet Printer
Printer error see your documentation
printer epson r390 printer error please see your documentation
Nov 02, 2009 | Epson Stylus Photo R390 InkJet Printer
EPSON STYLUS PHOTO RX685
try with chip reset for all you cartridge
Jun 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Error with me epson r300
Hi-
when you go ro check ink levels- is it saying that there is a specific cartridge that you need to change? red light indicates no ink and all of the cartridges should have ink in it. try uninstalling cartridges and reinstall it and make sure you hear a click when you press it down. if that doesnt work,call epson 562-276-1300 for a complaint and replacement of ink. best i got!
thanks for using fixya!
Jun 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus R380 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
