Question about Dell Dimension 4550 PC Desktop
My Dell 4550 has a cold start problem. It works great once its been running, it has to warm up for 15 to 30 minutes before it completely starts up. I have tried everything, started from scratch. I reformatted the hard drive, checked connections, reinstalled all software, updated BIOS, installed all Windows updates, all driver updates, anti-virus updates, ran the hardware diagnostics function (and no error codes). I've checked cords, pins in cords, reseated drive cables. What could be left to check.... Now scouring internet forums for an answer. You can hear the CPU working, light comes on, the cd drive lights come on as it runs through the beginning of the startup process, but then it just stalls and sits there, the monitor is black till that 15 -30 minute warmup is complete. Help
    Top Expert:
  • Dell Master
  • 12,962 Answers
Did you change the power supply ?- it is critical to the operation of your machine. Often if something is wrong with it,k it is not common for the machine to not boot up at all. Could be that until it gets warm some voltage is not up to par and the machine just waits till it is for it to operate properly.
Just make sure that your Dell power supply is not one of the older ones that had the wiring reversed and was not compatible with regular motherboards. Newer Dells are now compatible but older units can only use a Dell supply lest you burn out the motherboard.
Posted on Mar 18, 2017
fosabagali
  • 6 Answers
SOURCE: After loading Window service pack 3 update, comes up blue screen
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Posted on Sep 23, 2008
SOURCE: Dell Optiplex gx280 shuts down and orange power light blinks
I have had this happen to several systems and Dell usually sends me a replacement power supply - the power down to a flashing amber power light is regularly related to a PS fail. It can occasionally be a motherboard, but usually is not.
I would look at your power supply fan - is it running? When the power downs get closer and closer throughout the day, it shows signs of overheating (even though it does not show thermal events in the BIOS or logs).
Posted on Oct 06, 2008
pankaj_dic
  • 1252 Answers
SOURCE: Problem with startup of XPS 1530
try run vista on safe mode
Posted on Nov 27, 2008
Cytherian
  • 124 Answers
SOURCE: Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Posted on Dec 30, 2008
  • 2692 Answers
SOURCE: Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
http://www.seagate.com/www/en-us/support/downloads/
Posted on Jan 15, 2009
Carbeurator problems
Cold starting problems from a carbureted engine? Bet if you get your choke adjusted right, it will solve it. If you can screech the tires, this Tercel may be worth saving!
Just get a mechanic friend or pay someone to fix the choke. Doesn't take a long time if you know how. If you've never adjusted or worked on one, it's not so fun. Hard to explain too. The choke plate or flap should be almost closed completely when starting. Soon as engine is cranked or running, the plate should open a small amount more, but still nearly closed. Then as engine warms, the plate should gradually open until it is completely open after about 5-10 minutes. The choke cuts off the air supply to the engine. A cold engine needs a richer gas mixture to run good, and most importantly to start easy.
Nov 07, 2013 | 1988 Toyota Tercel 2 Door
Very hard to start but once it idles for a minute it runs great any suggestions?
cold start is not working right,, thats why its hard to start, when it warms up a little it runs ok,,,,fix the chock!
Nov 14, 2009 | 2003 Buell Blast
My Dell Dimension 4550 won't recognize my CPU.
your problem is the same as trying to put a AMD3 into a AMD2 socket, yes it fits and yes i physically should be able to run it it but in reality it won't
Sep 26, 2009 | Dell Dimension 4550 P4 Socket 478B...
The 2000 mountianeer starts and runs fine but shuts off
CHECK THE COLD START ENRICHMENT VALVE AND OR THE IDLE CONTROL VALVE. I AM ASSUMING THAT YOUR VEHICLE IS FUEL INJECTED. ONE OF THOSE HAVE GONE BAD.
Jan 24, 2009 | 2000 Mercury Mountaineer
Runs poorly while warming up
auto choke controled by the hot water system,sounds like someone has disconnected the pipes somewhere along the line as they were leaking,on or around the carb should be a round thing with two water pipes and inside is a bi-metal strip,which is most likely working but with no water through it or through the inlet manifold to preheat the petrol vapour hence your problem.soloution buy a small engined europen type vehiclelike a kangoo or berlingo and recycle the gas guzzler you have now.
Dec 28, 2008 | 1990 Toyota Pickup
96 960 cold start problem
take it to a volvo dealer and have the codes read
most likely a coolant temp sensor, ambient temp sensor, Baro sensor, MAP/VAF sensor problem the fault codes will tell you
Mar 18, 2017 | 1996 Volvo 960
2003 vw jetta wolfsburg bogs on early acceleration
Don't know if it applies to your diesel but most later gas engined vehicles have a 'cold start' valve that supplies additional fuel to the fuel/air mix along with boosting the idle speed until some warming of the engine is sensed.
Nov 14, 2008 | 2003 Volkswagen Jetta TDI
1991 dodge colt won't idle when engine is cold.
probably oil, it may be too thick when it's cold but once it warms up it liquefies and your engine runs smoothly. you could try changing oil, I'm guessing if you have a high performance oil the chances this is the problem may be greater since high performance things are usually geared towards working well when everything is hot
Jun 29, 2008 | 1991 Plymouth Colt
Dell Dimension 4550 PC Desktop Logo
52 people viewed this question
Alun Cox
