Question about Karcher Garden
RE: Karcher Ser.#122783 Pressure Washer K3 97M My Karcher is several years old. During recent efforts to use it, the unit "chugs" when I squeeze the handle rather than making the familiar steady pumping sound. The pressure is also down significantly. I will appreciate your input on how I might address this problem. T A Rounds
3 Suggested Answers
  • 174 Answers
SOURCE: when I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Posted on Sep 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Posted on Apr 18, 2010
Karcher pressure washer won't switch on.
revisa el cable de corriente, verificado esto.. puede ser la tarjeta quemada
Oct 11, 2013 | Karcher K 3.98 M Electric Pressure Washer
I HAVE AN OLD, ABOUT 15 YEARS,PRESSURE WASHER MODEL 270M. RECENTLY IT STARTED TO PULSATE WHEN I ACTIVATED THE WAND CONTROL. IT PULSES AT THE RATE OF ABOUT 1 SECOND INTERVALS. IT WILL NEVER STOP AND RUN. I...
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher k 3.99 does not pause correct
Is there a water leak from the bottom ?
Is so, then there maybe a small crack in the seam of the plastic manifold pump housing or one of the connecting fittings. A New Manifold Complete about $61.00. You may purchase direct from Karcher, and replace if you are mechanically inclined.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
May 09, 2010 | Karcher K 5.85 M Electric Pressure Washer
The water pump
Any possibility the unit froze this past winter? They do have to be winterized.
May 05, 2010 | Honda Karcher G2400HH-R Pressure Washer
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
Is there a water leaking from the bottom ? If so then there maybe is a small crack in the Pump Plastic Manifold Housing. A New Manifold Complete Replacement is approx. $61.03 from Karcher, if you are mechanically inclined.
Mar 16, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
88 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
