Question about Seiko Watches
Where can I find a manual for a Seiko westminister whittington chime clocki I cannot reset the chime
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 | Watches
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
Second hand adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SEIKO watch manuals.Rate me, please.
Mar 30, 2010 | Seiko Sportura SNJ007 Wrist Watch
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
96 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
