Question about GE Monogram ZEU30R Electric Cooktop
I get error code F153 when I try to turn on the right front burner on my GE Monogram cooktop model number ZEU30R. What is causing this and how much should I expect to pay to get it repaired by a service technician?
3 Suggested Answers
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Monogram 5-burner gas cooktop has a constant
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 23, 2010
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
How to change wb30t10062
remove the cook top from the counter and the remove the glass top, several screws around the edge of box. the lift top and you have access to the elements.
Jan 05, 2012 | GE Monogram ZEU30R Electric Cooktop
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Ge monogram cooktop model#zeu30rsf1ss error code f1 74
Hi There
I have found the codes that you need and hope this helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | GE Monogram ZEU30R Electric Cooktop
May 21, 2009 | GE Cooktops
Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Jul 17, 2008 | GE 30 in.JP950 Electric Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
GE Monogram ZEU30R Electric Cooktop Logo
137 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
