Question about Amana Haier AP095R Air Conditioner
Amana APO95R Turning Off/Tank Light (!) On and Off
My Amana APO95R is just under a year old. It goes off after a half hour; even 15 minutes. The tank full light came on and so I emptied out the water through the water drain pipe. It then worked fine for 3 hours and then turned itself off. Any solutions before I crate it back to Amana?
  • 828 Answers
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
Posted on Jun 15, 2008
  • James Helmer
    James Helmer Jun 16, 2008
    Did your unit come with an exhaust kit? If so use it. The evaporation part means the water condensate for the air is evaporated on the condenser coil. It should still be vented to the outside air.
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
JLTDC01 Dryer not collecting water in the tank
ck your vent hose,there may be a block vent not allowing air to move around clothes , causeing long drying times.if vent hose is ran long way.more then 4ft say 15 or longer,it should be cleaned once a year or replaced.this in my opinion is the most main problem when having dryer issues.
Feb 25, 2013 | Dryers
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Dec 05, 2010 | Water Heaters
Fuel light comes on and bike stalls, can restart straight away
Try adding Lucas injector cleaner to a tank of gas. I'm hearing a lot of R3 owners are having issues with the ethanol in our gas. I tried it in mine and it's all but eliminated the problem. Going to drain the tank and start fresh in the spring. Good luck!
Sep 29, 2009 | 2008 Triumph Rocket III
2006 GMC Envoy gas gauge not functioning properly.
GM had a problem with the fuel sending unit cards inside the fuel tank,If you replace that you should be good to go.
Sep 27, 2009 | 2006 GMC Envoy
Car stutters like it's starving for gas. Have a few issues that I could use help on. 1. Car runs great in the morning (1 hour drive). In the afternoon on my way home (about a half hour in), it starts to...
Gas cap has no bearing,lol. Check the wiring under the battery tray. They're notorious for corroding through the wiring & cause a short to the ecm. This results in retarded timing & wierd stuff going on. Write back if you need more. Old car,lots to check.
Jul 16, 2009 | Dodge Dynasty Cars & Trucks
Need On-Line Manual for Amama Portable A/C #APO95R
homeappliance.manualsonline.com/ex/thread/view/.../357803
Portables do not need venting.
Jul 07, 2009 | Amana AP073M 20" Portable Air Conditioner...
Heating & Cooling Logo
378 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
