Question about Kenmore Elite HE4 Electric Dryer
I pick the setting I want, but when I push the start button it just beeps.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
I have uniden exa 915 . Problem: When you pick up the cordless hand set and push the talk button you get a beep,beep,beep and but no dial tone.I put a new battery in two mo. ago and just to make sure I put...
Its lost its "link" to the base unit, you need to re link them this is either dont thru the menu system on the handset or pushing a button underneath the base unit and THEN re linking it via the menu.
Oct 23, 2009 | Uniden Lands Phones
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Watch is Beeping loudly on every hour!
While pushing and holding the RESET button in, press the START button to toggle between CHIME ON/OFF.
Mar 13, 2009 | Bulova Men's Watch
Innovage (1604007) Corded Phone
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
Feb 07, 2008 | Innovage 1604007 Corded Phone
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
