Home | Dehumidifiers | Water collection
Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Water collection
By Pete759 on Jun 15, 2008
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it off for several hours, I later find over a quart of water in the collection bin.
I do have a high humidity rate when I run the unit and a temperature of over 70 degrees out. Can you tell me what is wrong and if it is something I can buy parts for and repair myself if needed?
Same Problem
Jan 15, 2009
-   Had this issue as well, put off looking for a solution, and then took it apart to check and see if any obvious problems were showing. I disconnected the power switch connection, and then reconnected it after looking around inside. Now nothing happens, except a clicking noise in the switch when turned to Extra Dry. Even before disassembling, the "Normal" mode had stopped allowing any operation of the unit. -   psytrox
Nov 01, 2008
-   I have the same problem, and don't know how to go about getting it fixed, or trying to finx it myself. Any advice?-   bderrick
Solution #1
posted on Jul 17, 2008
Somewhat Helpful)
maybee500
Rank: Wiz
Rating: 89%, 28 votes
the unit is iceing the coil ck for air flow clean coil or its a more serious poblem like refrigerant or compressor capacity dan
Was this helpful?
Yes
No
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
its very loud when the compressor turns on
Answer
My hd656e comes on put the display will show low then the machine shuts down. I have moved the... (More)
Answer
it doesn't collect any water in the bucket . i haven't used it in weeks and when i runed it for a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
