Question about RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
My leaf eater starts to smoke. Where, or is there a place to oil the moter?
  • 37 Answers
The electric motor should not need oiling sounds like you are running on a lightweight ext cord and under powering motor try hooking up to a plug directly into outlet see if problem persist
Posted on Nov 07, 2010
Smoke came out of the leaf blower while using it and it will not start again. What to do?
1 obtain new spark plug
2 completely empty the gas tank including the gas lines
3 Carefully remix proper amount of gas to oil ratio and try again.
Most Gas leaf blowers / weed eaters run on Gas mixed with Oil, if too much oil is present smoke will appear the spark plug will foul and it wont start. additionally nO oil at all in the gas will cause the engine to smoke seize .and never ever start again. so if you can still pull the starter rope try the above
:note: most small bottles of oil mix will do two gal
May 02, 2018 | Garden
Do I need to mix oil with the gas?
Yes most small engines like weed eaters,leaf blowers,chainsaws,etc are a two stroke engine look on the cap or a sticker on the the machine has a gas drop and a oil symbol hope this helps
Nov 22, 2015 | Garden
Poulan ss428s using to much oil
The engine only uses about 3 ounces of oil so if you are consuming oil and you dont see smoke just keep topping it off!
If it is smoking excessively you may have engine damage with resultant oil loss past damaged rings or cylinder wall.
You can pull the spark plug and look into the cylinder and see if you notice any major galling. Also a compression test would be a good idea to verify fit and function of the rings and sealing surfaces.
Jul 09, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Oil in the gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Oct 05, 2012 | Toro Lawn Mower With Toro Power Tools
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
What is the gas and oil ratio for Weed Eater leaf Blower GBI 22V? please
40:1 which is 3oz. of 2 Cycle Oil to 1 Gallon of gas.
Jim
Aug 15, 2011 | Weedeater Gas Blower
What ratio gas to oil do I mix?
Use 3.2 oz of 2-cycle oil to one gallon of gasoline. If you use 3.3 up to 4 oz you would be okay nut it may smoke a little. Sorry to hear about your husband. Good luck...Lee
Jul 29, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Volvo 850 smoke coming from exhaust manifold
Not to worry. Run the engine up to operating temp before jumping to conclusions and let the heat burn off any excess oil. A leaf will not do any damage.Do not let the engine overheat while idling and if the oil light comes on switch off immediately.
The smoke from the exhaust is oil deposited by oily assembly hands just burning off. It should dissipate after about 15 minutes at most.(or 5 miles' drive)
Jun 07, 2010 | 1994 Volvo 850
Leaf blower will start, run for about 3 secs, then dies. Blue smoke comes out of it.????
blue smoke is the sign of burnin oil try putting oil in thr cylinder about two tablespoons of oil the blower should run long enough to the oil is burned out that will tell it is the rings but sometimes it will free the rings and keep on running if your lucky
Nov 06, 2009 | Yard Man Garden
Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Aug 09, 2009 | Garden
RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag Logo
100 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
