Question about Westinghouse 32" Flat Panel LCD HDTV
WHAT INPUT SHOULD IT BE ON WHEN CONNECTED TO THE CABLE BOX
  • 129 Answers
Depends if you are using HDMI or Cable or TV.
Thank you
Posted on Nov 07, 2010
How to set up a cable box?
Connect cable wire out of wall to cable box input. Attach cable wire or HDMI cable from cable output to the appropriate tv input. Turn on cable box & tv. Goto source on tv and set it to the corresponding input that you connected to the back of the tv. If your tv does not have a HDMI input then you will not get hi definition tv. You can get digital. If you got a digital adapted you follow the same procedue but instead of a cable box you connect the digital adapter.
Jul 01, 2015 | Televison & Video
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
May 21, 2014 | Televison & Video
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
May 25, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
I cant get go video model #r6740 to be able to be connected to my cable box and still work help please
connect the yellow, white, and red cables from your cable box (output) to the (input 1) connector on the dvd recorder. Then connect the yellow, white, and red cables from your dvd recorder (output) to a (input) on your tv (make a note as to which input on the tv you use). then turn on your tv (set your tv by pressing input, line, or channel down from channel 2 until you see the input you connected your dvd recorder to). then power your dvd recorder on (you should see it on your tv screen), then change the input on your dvd recorder to input 1 (or which ever one you connected your cable box to). Then power on your cable box (now you should see your cable programming on your tv, passing through your dvd recorder). Now you should be all set to watch, and record what ever you want, (however most dvd recorders will not record copyrighted materal, their is a signal transmited ny the owner of the movie, or other content.)
May 11, 2008 | Televison & Video
Westinghouse 32" Flat Panel LCD HDTV Logo
62 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
