Question about Philips FWC399 CD Shelf System
Can't play CD's
When inserting a CD, readout says "disc not finalized".......I could understand this if it were ones that I had burned but this happens constantly with CD's that are bought from the shelf.........CD player is not usable........what's my recourse or corrective measures.......I don't buy stuff like this just to throw it away in a year or so......please advise to
pt@suite224.net
  • 1,879 Answers
Something went wrong during disc burning
nero for example has an option to finalize disc that will be burned
Posted on Jun 15, 2008
    Guru:
  • 1,894 Answers
Try to burn a finalized disc and play it.
does the error message repeat or not?
    Genius:
  • 3,422 Answers
The laser lens in your player might be dirty or failing.
Try the following solutions:
Clean the laser lens with a DVD player lense cleaning disc.
Lense cleaning discs are available at many electronics retail store and websites.
  • Priya darshan Jun 15, 2008
    According to the user manual if the message "disc not finalized" then the solution is to Use a finalized CD-R(W) or a correct format disc.But you face the problem with every disc then the problem can be with the lens itself as i said before.Anyway please follow few troubleshooting steps given below:
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image i have attached.
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
What are the steps to record cd to cd
rip your cd on a laptop/pc and put in a blank cd and burn it to that simple option!
Aug 07, 2012 | Teac RW-D250 2-Disc CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Just bought a used sony cfd-c1000. It will play most of my burned cd's but not one specific one: they are all on cd-r and I burned them all the same way with the same program, any ideas why it won't work?
My first two thoughts are: 1) It's a defective disc or 2) The disc wasn't finalized after it was burned. CD-R discs will not play on any machine other than the one that they were recorded on until they are finalized on that recorder. If it will play on the recorder and it has been finalized then just burn another copy of it. I have seen disc compatibility issues on one disc out of a stack of 100 before.
Nov 27, 2010 | Sony CFD-C1000 Cassette/CD Boombox
I have a sony CFD-S01 which will play commercial cd's but when a cd-r is inserted it either won't recognize the disk or it jumps constantly after appros 10 sec, any ideas?
The CFD-S01 is designed for use with CD-R and CD-RW discs. With that in mind a few things come to mind. Are the CD-R discs you are using music or data discs? There is a difference and some CD players do not get along with data discs and won't play them well if at all. Also the burn rate used can have an effect - too fast and it won't play well. If a disc doesn't play at all it might not be finalized. A disc must be finalized on the recorder it was burned on before it is playable on any other machine.
Nov 27, 2010 | Sony Boom Box With CD Player & Cassette...
I have an HP Pavilion mx704 desktop PC 2005 model, and I can not burn music onto a CD. This computer has a CD burner, and when I start burn of the downloaded song, it says insert disk, I put a blank CD-R...
What OS and burn software are you using? Can you see the music files when you look at the file explorer on the computer (My Computer or Computer in Windows and double click on the optical drive)? Check if the disc has any scratches.
If you see the music listed on the optical disc, check if the disc was finalized. (Again in Windows Computer, right click on the optical drive and it should be an option if the disc hasn't been finalized.)
If there are no files on the CD-R, make certain that the disc isn't being formatted before you try the burn. (Formatting should only be done on R/W discs.)
If the music files are on the optical disc and the disc was finalized, your CD player is not tracking across the disc properly. Try a lens cleaner. It may need repair and I've never successfully repaired a CD drive (the only ones I've had fail were in computers and were cheaper to replace). The mirror and the belt are the most likely places to have issues.
I hope this helps.
Aug 06, 2010 | HP Computers & Internet
I have just burned digital photos to dvd+rw disc.When I insert the disc into our Philips blue ray player (BDP3000) it reads ''unknown disc.''Why is this? The manual states that these discs should be...
Chances are the disk is not finalized. dvd+r and dvd+rw need to be finalized before they can be viewed on any other player than the one they were made on. If you have the instructions to the burner, then it should be easy to learn how to finalize the disc. If not, I would suggest googling the burner and find online instructions. Good luck!
Apr 01, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
Loading some DVD's
I have seen this same thing on a laptop. DVD drives use two lasers. One for CD and one for DVD. As you noted CDs are just fine and so is that laser. Although I believe the DVD laser is intermittent. And it will work with some DVDs and not others. Yes I have seen this before. What will probably happen a few months down the road is it will stop reading all DVDs.
It isn't economical to replace the failing laser. It is far cheaper to just replace the whole DVD drive. Lasers are like light bulbs. Some seem to last forever and some seems to burn out right away. Generic DVD replacements will generally work, although the face plate might not fit.
Another option is to get an external DVD that plugs into the USB port. And those Slimline models are really small (same size as laptop CD/DVD drives) and you can use them on other computers too.
Jan 29, 2009 | Computers & Internet
Won't read mp3 and wma cds
The discs were not "finalized" or "closed" - place the cd's back on your computer cd-rom drive and search the help file of your CD burning software and search for "closing disc" or "finalizing disc." Some programs will allow you to close or finalize after you have already burned them, but others (Sony SoundForge is one exmaple) will not allow it - you may have to re-burn the discs and select the option that says "close disc after finishing" (this option is usually left unchecked by default, because closing or finalizing a disc prevents you from adding any new information to the disc).
-Tha Mp3 Doctor
Jan 02, 2009 | Panasonic CQ-C300U Car CD/ MP3 Player
Philips FWC399 CD Shelf System Logo
319 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
