Picture on large screen lcd tv, which is only 2 months old, has a green fuzziness to it. started intermediantly, now is constant. Some scenes are easlier to see than others; dark scenes show the green fuzzy the worst. Help please! Thanks.
  • 4,889 Answers
Since the tv is only two months old, it must be under warranty. Considering the fact that this cannot be fixed just by changing a few settings, it is best to call the customer support of the manufacturer. If you can just get me the make, I can get you the contact info.
Sai.
Posted on Nov 07, 2010
Green screen upon shutting down or green color replacing black .. Fuzzy green on some dark scenes.. Sharp Aquos LCD TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 29, 2015 | Sharp Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
My LCD tv model LN46A650A1FXZA picture turns green after about being on for 5 minutes. Then is gets fuzzy and green
I have the same issue. TV is ~ 2 yrs old. Ruled-out cable-box & HDMI cables (green present in menu mode with no cables attached).
Screen turns mostly green, with a crappy picture. After a few days, a normal picture just appeared. Today I powered-on, the green screen stuff came up, then a minute later a good picture for about 20 minutes, back to green-stuff for 10 seconds, then good picture.
Did chavez_debi get her issue resolved?
Aug 05, 2010 | Samsung LN46A650 46 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Pixelation - picture update unable to keep up with signal 32" LG Lcd Tv less than 2 months old Generally resulting when there is alot of changes to the image on the screen. i.e. with action scenes. At...
If the signal has not changed, then the problem is internal to the set. Given that this unit is only a few months old, it is still under warranty. Request a warranty repair. This should be repaired or exhanged at no cost to you. It sounds like the digital processing section is defective.
Dan
Nov 30, 2009 | LG 32LG30 32 in. LCD HDTV
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Sony KP-57HW40 57 in. Green Circles
well just remember the in the electrical industry its not 100 percent all of the time. you might just want to buy a new one.
Apr 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
