Question about D-Link AirPlus DI-614+ Wireless Router
Cannot get Blackberry pearl on internet
It sees the wireless but either says cannot connect or cannot obtain IP address. Hooked up to a friends and worked fine but will not work on mine.
  • joebottoms1 Dec 25, 2008
    I have a DI-524 router in my home... But I cannot get my blackberry Pearl with wifi to work through it like it should.. I just got it this morning so i haven't had the chance to try it on any other networks
Had same issue with a BlackBerry 8320. Disabling the 22MBps on the DI-614+ fixed the problem (in performance, advanced tab, select 1-2-5.5-11 MBps for TX and Basic rates).
Posted on Aug 21, 2008
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
Have a Belkin N150 router. Status constantly says acquiring network address. If you go to the support part it says invalid ip address.
Make sure your wireless card is set to acquire the IP address automatically. You can do this by going into:
  1. Go to "Start Menu >> Control Panel >> Network Connections"
  2. Right-Click on "Wireless Network Connection"
  3. Click on "Properties"
  4. Double-Click "Internet Protocol" which you should be able to see in the small list in the box
  5. Now you will be able to see an option to "Obtain IP address automatically" and "Obtain DNS server address automatically". make sure that both of these options are selected.
If you have Windows Vista or Windows 7, the flow is the same, but certain options are labeled differently:
  1. Go to "Start Menu >> Control Panel >> Network and Sharing Center"
  2. Click on "Manage Network Connections", which is located on the left hand side of the window.
  3. Right-Click on "Wireless Network Connection"
  4. Click on "Properties"
  5. Double-Click "Internet Protocol Version 4" which you should be able to see in the small list in the box
  6. Now you will be able to see an option to "Obtain IP address automatically" and "Obtain DNS server address automatically". make sure that both of these options are selected.
  7. Repeat 'STEP 4 and 5', but this time select "Internet Protocol Version 6".
you can check the IP address of the connection by checking ipconfig:
  1. Click on "Start >> Run" or "Start >> Start Search bar"
  2. type in "cmd" and then press "Enter"
  3. In the black box that appears on screen, type in "ipconfig" and hit "Enter"
  4. This will give you a long list of information about your connection. There should be a small heading called "Wireless LAN Adapter Wireless Network Connection" or "Ethernet Adapter Wireless Network Connection".
  5. This will have an "IP Address" or and "IPv4 Address". If the IP Address starts with 192.168., then it means it should be functioning properly. If it gives you a 169.254. address, it means the laptop is likely faulty.
Hope this helps
Mar 05, 2011 | Computers & Internet
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
I just bought a epc P701 computer and I want to use the internet in another room. I have a laptop with a wireless router hooked up to this one in another room. For the epc I dont know how to get the...
It appears that your notebook has wifi capability. You need to be certain that your network settings are correct. You need to get to your wireless network settings. Follow these directions:
Go to My Network Places, right click on My Network Places to get a menu
Choose Properties on the menu, You will see a new window open
Look for the wireless network connection and right click on the wireless network to get a menu
choose Properties to open another window. Look inside the window for TCP/IP settings.
Click on TCP/IP and choose properties.
Make sure that "Obtain IP address automatically" and "Obtain DNS address Automatically" are both checked so that you are able to connect to your wireless router. That is the usual TCP/IP settings for most home networks.
I hope that this helps.
Brian
Dec 24, 2010 | Computers & Internet
My linksys system is hooked up to my desktop & is working fine. I'm able to see & conect to my wireless network via my iPhone as well. My problem is with my laptop. I can see my network & it...
Hi
it may be a problem with the ip address
try this
go to start>control panel>network and internet>network connection/network and sharing center.
for XP:
right click wireless network connection>go to properties>highlight internet protocol (TCP/IP)> click properties> make sure that both radio buttons are on Obtain..
for Vista:
go to Manage network Connections ( on the upper left-hand cable ) > right click wireless network connection>go to properties>highlight internet protocol version 4 (TCP/IPv4)> click properties> make sure that both radio buttons are on Obtain
Sep 14, 2010 | Linksys Wireless-G WRT54GS Router...
Our Ip address has been changed to a different number and has now locked our laptops out of the internet. How do we fix it?
Steps to Change Your IP Address
Windows XP/2k users
Go to Start -> Control Panel -> Network Connections -> Local Area Connection -> Properties -> Internet Protocol (TCP/IP).
click properties tick obtain an ip address automatically and ticks
obtain DNS server address automatically
or you can go to this website see how to change you ip address
http://www.tech-faq.com/change-ip-address.shtml
Jan 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
My computer reads my router but i cant connect to the internet through it
try setting your computer to "Obtain an IP address automatically" you might have changed your IP address that's whyn you cannot connect through the internet. got to your wireless connection status>properties>scroll the bar down and you will see the internet protocol (TCP/IP) click once to highlight and the click properties. after thata window will come out and just mark the Obtain an IP address automatically. after that click ok then close the application and refresh your network list. if it did not help, iw will find another way to fix that.
Dec 21, 2008 | Computers & Internet
Trouble connecting wireless
first thing to do is to dissable the ethernet connection in network connections on your notebook so as the ip address does not conflict.
assuming it's XP and assuming DHCP is enabled in the router settings, right click on your wireless conection in network connections, properties>TCP/IP line, highlight it and then click properties again, then ensure obtain an ip address automatically is ticked, apply and ok, close window.
If neccasary run the wireless network wizard in new connections in network connections.
Open internet explorer>tools>internet options>connections tab and ensure that 'never dial a connection' is ticked, ok and close IE.
Open IE and click refresh a few times.
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link AirPlus DI-614+ Wireless Router Logo
526 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
