Question about Dewalt DC616KA 18 - Volt 16 - gauge Straight Finish Nailer Kit
DC616 Nailer won't fire? - Dewalt DC616KA 18 - Volt 16 - gauge Straight Finish Nailer Kit
4 Suggested Answers
  • 8 Answers
SOURCE: cordless nailer dc616 shoots couple of times then
Check to see that battery is pushed tightly up against its seat. I recommend you take it out and reinstall with a little extra umpfgh to the process. Also, it could be either the battery isn't charged enough, or you need a new gas cartridge in the unit
Posted on Jan 15, 2010
  • 4 Answers
SOURCE: How do i replace the
I believe the manual has a whole section on how to remove it and replace it.
You will probably have to buy a whole driver/return mechanism.
Posted on Mar 20, 2011
  • 46412 Answers
SOURCE: My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Posted on Aug 13, 2015
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
DC6t16 nailgun I have a nail stuck lengthways in the magazine. This stops loading nails. How can I remove it
The bestthing to do is get you a good screw driver and just sit down and start prying it out of there, will take a minute or 2 but will eventually come out
Jul 26, 2011 | Dewalt DC616 16g Cordless 18v Straight...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
How do i replace the driver blade in a Dewalt DC616 finish nailer?
Dec 31, 2010 | Dewalt DC616 16g Cordless 18v Straight...
My DC616 a straight 16 gauge DeWalt finish nailer tries to drive 2 nails when it fires 1 out of about every 5 to 10 shots. I am a finish contractor and have used this nailer for about 6 years. I was...
Argh...
Had the same problem, but only after about 4-5 nails. Once it jammed 4 times in a row - very frustrating.
I read the manual, took the unit apart, checked the driver - it was straight. I took a file and filed the back end of the driver down a bit so it would miss the second nail and so far it seems to be working famously.
Great unit...
Sep 07, 2010 | Dewalt DC616 16g Cordless 18v Straight...
My dc 616 wont fire. the lights are on solid when first put battery in then when you depress nose to fire, it clicks and the lights flash constantly thereafter
The driver is probably stuck. The manual tells you how to access the front of the device. Check there (I have also had several hard to find jams) - be sure to remove all nails first.
The driver is silver in color, so it's easy to see if it's jammed. Use a slotted screwdriver to push it back up. I have had this happen more than a few times.
Aug 13, 2010 | Dewalt DC616 16g Cordless 18v Straight...
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Nov 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Dewalt DC616KA 18 - Volt 16 - gauge Straight Finish Nailer Kit Logo
60 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
