Question about Magic Chef Refrigerators
Freezer remaining cold, and although fresh food area has been slightly freezing, at low setting,---after 7 hour power outage yesterday, fresh food area will not get below 39 at coldest setting. ?????????? THANKS
  • 525 Answers
You don't provide a brand, style, or model number, so I can only offer a limited answer to you.
Firstly, make certain that both controls are set to equal numbers, 5 preferably,(or D if letters, depending on brand),
Make sure all doors are sealing properly, and if so make sure that no one opens the doors for 8 hours minimum.
Make sure that your are monitoring water temperature and not air temperature. Monitor the readings every 8 hours minimum.
If you are satisfied with my advice please ackowledge by rating my answer, or post me back with more info. so I can be of better assistance to you,
Thank you,
Dave E (Illeagle)
Posted on Jun 15, 2008
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Temperature regulation not working (max only), water dispenser not working and ice maker not working although dispenser works
The symtoms sound all to common on GE units. Based on your symtoms I suspect the fresh food area is to cold. The damper assy is controled by the motherboard / thermistors. This damper assy adjusts to control the air movement from the freezer. During its cycling it can snap loose when this happens the air from the freezer is uncontroled. Within a few days the fresh food compartment temps can drop below freezing. The drop in temp also can freeze the water reservoir behind the lower crispers and in some cases the water filter. Altho You may have other issue (i.e. filter, bad fill valve assy, motherboard) the above statement happens 70% of the time. Fresh food damper assy part# WR49X10091 est $135.00.
Ric
Mar 09, 2010 | GE GSS25LGM Side by Side Refrigerator
Food is freezing on our top refrigerator shelves
well i'm not exactly sure what fridge you have but that is usually caused by the what they call a baffle...which is a flap that opens and closes to let the cold air from the freezer to the fresh food side. It sounds as if the baffle is stuck open or moving way too slowly and thus freezing your fresh food. You can find a part number and price at partsselect.com all you need is your model number. Good luck!!
Oct 03, 2009 | Refrigerators
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not get as cold as I would like
First check the condensor fan and condensor for dust and make sure they are clean. If these areas are not clear the system will not operate correctly. You should be able to place your hand down low on the front of the frig and feel warm air coming out of the grate there. The presence of a flow of air meens that the condensor fan is working. Depending on how forceful the air flow is, would depend on how much dirt and dust the condensor has collected. The temp controls should be set to midway first. There is a dilicate balance for these settings. Over adjusting can cause problems. Then after several hours check the frig. If not cold enough. Adjust only the fresh food adjustment colder a little bit at a time. Repeating this untill your fresh food side is cold enough. If you over adjust the fresh food side too much then food in the fresh food side will begian to freez. If you set the freezer side too high you may be causing too much frost build up on the evaporator and lowering the air flow to the fresh food side and causing it to be warmer than it should be. This would be a check to see if you can balance the frig temp. If you can`t get it to balance and there are no restriction of air flow in either the evaporator or condensor, then we may have to look farther into problems with the compressor. You may need to check for some ice buildup around the air inlet in the fresh food side from the freezer side. Try this and let me know how it is.
Nov 13, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
May 20, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerators Logo
173 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
