How does a hard drive looks like? I'm getting a error msg saying that hard drive is bad!!
    Problem Solver:
  • 5 Answers
Has that drive always been installed in that computer?
Try it back in the external enclosure and see how the drive is listed in Disk Management.
While in the external enclosure you could have viewed the status of the drive in Disk Management. That may have shed some light on things. You can also run a drive fitness test on the drive. Either while in the computer or in the external enclosure.
Most drive manufacturers have dedicated software to check the drive integrity. Download it from the appropriate manufacturer. Versions that can run from a boot disk or from inside Windows may be available.
Still if your problem is not solved, i believe this site could help you:
http://www.computing.net/
Thanks for using Fixya. Please rate the solution.
Posted on Nov 07, 2010
  • 12 Answers
How old is your hard drive ? Hard drives eventually fail due to normal usage or it could be something else. You need to provide more information.
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
Hi, I bought DELL INSPIRON 1545 in India two years back... now i am experiencing a trouble in it... It says the following error occurred: Error Code: 0146 Msg: Error Code 2000-0146 Msg: Hard Drive 0...
ok, the good news, the bad news, and the ugly.
Good news: buy a replacement hard drive and you should be good to go. Bad news: data recovery on a failed drive is a crapshoot at best- there are ways to try and recover, but they are stopgap (and cheap) or mostly reliable (and freaking EXPENSIVE)
Ugly: buy an external cage to install the hard drive, use a boot cd of Linux ( I've had better luck pulling files from NTFS drives using Linux than another install of Windows. Go figure....) and put the hard drive in a freezer bag- **** ALL AIR OUT OF THE BAG!. Put drive in freezer for 48 hours.
Pray. Pray hard. Pray harder still. Put drive in external cage, attach to linux system. Pull as much info as you can. Hopefully you can snag your important files- but that error is a pretty gnarly drive error.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 22, 2011 | Computers & Internet
Error Code: 0146 Msg: Error code 2000-0146 Msg : Unit 1:DST log contains previous error (s) please help me, how i can solve this problem
I am assuming that this is a problem on a dell computer? If so that error message is an indicator that your hard drive is probably going bad and you need to back up you data and get a new one ASAP. I believe that laptop takes 2.5" 9.5 mm sata laptop drives
May 17, 2011 | Computers & Internet
Comoputer: DELl precision T5500 Workstation Problem: cannot start normally Error CODE 0142 Msg: Error Code 2000-0142 Msg: Hard Drive 0-Self-test unsuccessful Status: 72
sounds like a bad hard drive. Press f12 during the dell logo on startup and choose "diagnostics" from the boot menu, see if more failures relating to the hard drive are returned.
Feb 23, 2011 | Computers & Internet
Dell Laptop Vista repair stuck! My Dell Vostro 1500 does not start. It is Vista Home. So, I am trying to repair it with the installation disk. However, the installation stuck after the "Windows is loading...
leerobin
It does look like you may have a problem with the hard drive on the computer.
In regards to recovering your data if you have access to another computer you can connect the hard drive to it to see if the data is recoverable. Note since you ran the system recovery it may have over written your data. If this is the case then you might check with your local computer store to see if they have a hard drive data recovery program. As long as there is not a physical problem with the drive they may be able to recover the formatted data.
After that I would look at the top of the drive to see who the manufacture of the drive is then download there diag and repair tool for the hard drive. While you have the drive on the computer run a repair scan on the drive. If you just have some bad sectors then the diag program will zero them out and repair the drive. If the drive is indeed bad the program will tell you this as well.
If the drive is bad and your computer is still in warranty then you should be able to get Dell to send you a replacement hard drive. If you are not sure if you are still in warranty let me know the service tag of your computer and I can look it up for you. Also note you will want to have Dell send you your recovery CD if you do not already have it.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Computers & Internet
Getting a bios error msg....CMOS checksum
No problem, once and awhile I just cruise around on here. You can narrow the problems down by either replacing the ram/hardrive/expansion cards/cpu with known working parts, or putting the parts into another working cpu untill it stops working. My guess would first be to try removing the hard drive. Once you get a working combination, add the parts in untill you find a the issue component. If the problem persists, your looking at a bad harddrive controller or hard drive, that undermines your entire system's stability. If I am right your working with a socket A motherboard and thats pretty old so I wouldnt be suprised if it may be quitting.
Apr 28, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Error Code: 1000-0146
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Computers & Internet Logo
42 people viewed this question
Alun Cox
k24674
