Question about Toshiba SD-V295
NOT ABLE TO INSTALL PLAYER
TRYING TO HOOK UP THIS PLAYER, SHOWING THE IN CABLE BUT CAN'T FIND PLUG FOR OUT CABLE. NOT SHOWN IN THE MANUAL
Check the page 10 on your manual book.
Posted on Oct 28, 2008
  • ademekmark Oct 28, 2008
    or check the page 16. let me know if you find the solution.
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I am trying to record cartoons for my 4 month old onto dvd from cable... I cant quite figure out how to hook it up.
The device unit?U must have DVD/VCR recorder player to record things out of cable tv or other tv signals.Not just a DVD/VCR player.Read ur manual for instruction,u hook up a VCR before right,the same principle.
Dec 07, 2010 | Samsung DVD-VR357
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
Optical plug
optical cables will only go in one way. dont force it and break something. good luck
Feb 11, 2010 | Denon AVR-1801 Receiver
I cant get the music from my computer to download on my mp4 player help please?
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.plug your device on the cable.
a drive shown in the my computer send your music to the drive
Dec 28, 2009 | Apple Audio Players & Recorders
I am trying to hook up a DVD player using the s-3 video cable. Can get video but no audio. Where do I plug in the audio (RCA?) cable and is there a R & L for stereo?
You have to run the audio cables separately. There are audio input jacks associated with the S-Video cable input that you are using. You may have to consult the user instruction manual for details.
Jerry G.
Aug 06, 2009 | Olevia 227-S11 27 in. LCD TV
Trying to hookup dvd
Steps to hook up DVD player:
1. Plug in DVD player
2. Plug in VIDEO cable to back of DVD player
There are multiple video out cable options: HDMI, VGA, RCA
If you aren't sure, use RCA (red, white, yellow tri-plug cable) and plug yellow into VIDEO OUT port.
3. Plug other end of video cable into TV's VIDEO IN port.
4. Turn on TV to the INPUT channel that corresponds with the input port you plugged the video cable into. Usually, this is either VIDEO1, VIDEO2, INPUT1, INPUT2, or channel 3.
May 03, 2008 | Televison & Video
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Failes to detect mp3player
If you are using Windows 95, the player is not supported. If you are using Windows 2000 or XP, it will show the player as MTP player. If the MTP is not shown on My Computer, install the player as removable disk (use Device Manger, find the device connected, right-click on the player icon, and click Update Driver).
Sep 28, 2007 | Sony NW-E002 MP3 Player
Toshiba SD-V295 Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
