Question about Kenwood DNX7100 Car Video Player
Kenwood I have an indash navi, I am looking into purchasing a new system. I hate it because I cannot navigate while driving. An installer advised if I purchase any Kenwood model (ie: Kenwood DNX8120) I am able to access all points in the navigation and watch a dvd if I choose while the car is in motion without rigging the system, however, I contacted Kenwood directly and they advised me that is not possible. I do not want to throw away money on yet another system and find there is nothing different between this pile of garbage and the new garbage. I want to make sure I do not void a warranty, I can access all points on my navi, as well as, use all features (speed etc). please someone help me.
I bought the Kenwwod DNX7120 today 11/24/2008 All I did got a 12gauge or smaller grade about 6" long took the parking brake female out ( the plastic thing that connects to the side prong place on the pedal strip both sides of cable, one side obout 1/2 inch and put into the female plastic casing and plug it back in, took the other side strip it 2 iiches and loop it around the metal holder of the switch an put some tape. So you can press the parking pedal if needed and everything stays in place no dangling wiere. Very easy. you can watch video or use the phone book and make a call. wiout having to press the parking brake. WARNING!!!! DRIVE SAFE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 26, 2008
I have a 7100 and everything works while moving all you do is ground the p brake wire . should not void warranty because if you install the wire according kenwood it gets grounded when you apply the p brake anyway...
Posted on Aug 11, 2008
Wire the video wire to the hazard light switch.
Posted on Jul 03, 2008
You can do it on the dnx7100 as well as the dnx7120. I have had both systems. the installer needs to mess with a couple wires. the sales guy you were talking to is trying to up sell you. the only benifit I see in the dnx8120 is its bluetooth ready..
Posted on Jun 20, 2008
Owners manual for concept indash dvd
Good evening Owen.
You can get a soft copy of the manual from the Kenwood site at
http://manual.kenwood.com/files/B64-3185-00_00.pdf
Cheers
D
Dec 03, 2015 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Unit door open no dvd disc system is not working
I'm assuming you are referring to the Navigation system disc? If it's missing the navi system will not operate. You'll need to purchase a new one from Honda.
Mar 13, 2014 | 2005 Honda Odyssey Touring
KENWOOD DNX5120 DVD Navigation System GPS Receiver: I just purchased a used vehicle with this system. ...
Its a lil Play button at da bottom of screen wen on tuner! tap it until it say p1 p2 p3 etc, turn to wat station you want and hold either p1 p2 p3 etc!
May 09, 2010 | Kenwood DNX5120 DVD Navigation System GPS...
Kenwood DNX8120 can't acquire satellite signals
Check your antenna for a kink. Honestly I have seen the gps antennas on all indashs go bad very easily. Just check that make sure your good. If not you can try resetting the unit with the little reset button on the face.
Apr 07, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
Nov 20, 2008 | Kenwood KVT-512 Car DVD Player
AVX-P7300DVD
yes, you can. you will need to purchase the navigation system from pioneer. as far as programming / subsription, i don't know.
Sep 13, 2008 | Pioneer AVX-P7300DVD
Kenwood DDx8017 with navigation
Which NAV system are you using with it? KNA-G510, etc needs to be plugged into the NAV port on back and then you need to go into the System Settings to enable the NAV option and voice interruptions correctly. You'll want to look for AV Interface in the System Settings.
Here is the DDX8017 manual for some help:
http://inform3.kenwoodusa.com/manuals/DDX8017.pdf.
Nov 25, 2007 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Kenwood DNX7100 Car Video Player Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
