It won't drain water or pump out. I'velooked at the filter in the bottom and it was full of water but no debris.
    Genius:
  • 1,672 Answers
It means ur solenoid is not working to pull the diaphragm OPEN!
Check the wiring and your timer switch!
Posted on Nov 07, 2010
  • Bayyagg
    Bayyagg Nov 07, 2010
    Unclog the drain line if the machine is spinning but not pumping out water. If the problem still isn't fixed, the pump may need replacing
    Look for a broken pump belt or frozen water pump pulley if the machine does not spin or pump water. Test the pulley by disengaging it from the appliance and physically turning it. It should rotate freely.
Tip
Clean the pump filter screen on a Kenmore HE2 Not draining
  1. Unplug machine.
  2. Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
  3. Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...
  4. Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be careful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris.
  5. Once everything is cleaned out reverse removal procedures put back together.
on Apr 07, 2010 | Kenmore HE2 Plus Front Load Washer
Flashing code f05
F05 indicates no drain or pressure switch jammed on full. If it's full of water you need to drain this down first.
Take the cover off below the front panel, you may find a filter there. Put a container down and some towels.
Slacken the filter a little and drain the water. Tighten the filter to stop the water. Continue doing this till the water stops, then take the filter out, clean out the debris, ensure the pump is free to turn.
If your machine doesn't have a filter, pull the machine out and drop the hose into a bucket or wash basin. Raise the hose to stop the flow of water while you empty the bucket or basin. Once empty, unplug the appliance, tilt it back 45 degrees (assistance would be good), take the screws holding the pump in place and drop it out through the bottom. Take the hoses off, clear the debris and reassemble. If there is no water in the machine, unplug the appliance, take the lid off, locate the pressure switch, give it a few good taps with the screwdriver handle, take the thin tube off and blow down it hard to clear any debris. Reassemble.
Try the machine again. If the F05 persists then you're potentially looking at new electronic control board for the appliance.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose.
Oct 31, 2011 | Indesit W 123 Front Load Washer
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
My kenmore 665.1376 has not been draining. i dont think it is finishing its cycles correctly. when i open the door, the bottom is full of soapy water. i have to wait a day, then hit the cancel/drain...
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if this answer was helpful
Many thanks
Feb 13, 2011 | Dishwashers
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
After the full cycle is completed, there is 1 1/2 inches of dirty water in the bottom of the machine. Took off the hose from the garbage disposal drain but can't blow back at all. Any ideas?
water drain pump does not work. open the filter which collects the debris, so that you can drain the water as well confirm whether something is stuck in drain pump rotor, preventing its rotation. just clear it.
Mar 19, 2010 | Washing Machines
I have an kenmore elite with error code f02???
The drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap).
Unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Feb 20, 2010 | Washing Machines
Washer keeps stopping and is still full of water and the delay start button is flashing
Drain pump is either blocked or failed. Check the pump filter which should be at the front right of t he bottom of the machine. If this is clear, you may have to remove the pump to get debris out of the pump housing. Ly the drain hose on the ground to drain the machine first and unplug before going at it.
Dec 08, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
