Question about Refrigerators
MAYTAG SIDE BY SIDE COLD ON JUST ONE SIDE - Refrigerators
  • James520 Apr 17, 2009
    refrigerator side not
  • 4 Answers
JUST YOUR DEFROST
Posted on Jun 15, 2008
Maytag msd2655 freeze work good,fresh food side not cold
HI TRY DEFROSTING ALL FIRST.MIGHT HAVE ICE BUILD UP AT THE BOTTOM.IF IT WORKS GREAT. IF NOT THEN FURTHER INVESTIGATION REQUIRED.SERVICE COND/UNIT.GOOD LUCK ALI
Jul 12, 2012 | Maytag MSD2656G Side by Side Refrigerator
My Maytag wide-by-side refrigerator -- problem with the refrigerator side not being cold, but the freezer side is cold...What do you think needs to be fixed on the "refrigerator" side? Many thanks.
check the vents that separate the two refrigerator sides for good air flow: (no blockage, dead fan etc.) as there is only one compressor circulating freon coolant gas through both sides; cooling temperature is acheived by adjusting air flow vents (the cold control usually is not at fault.)
Apr 05, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 28, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
Aug 29, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
