Question about Kenmore 54701 Dehumidifier
Sensor light detecting full bucket when its not full
4 Suggested Answers
  • 53 Answers
SOURCE: Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: My dehumidifier bucket fill light is on and the
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Jun 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: Full Bucket light stays on so dehumidifier will
If you don't have the manual it's here for free...
http://www.retrevo.com/support/LG-LHD45EL-manual/id/17335ci969/t/2/
Look at the picture in the upper right corner of page 12. The RED button is located in the upper left rear of the bucket cavity.
It may be jammed. Tap on it to make sure it moves freely. It must be pressed IN to indicate NOT FULL and allow operation. You should hear a click when it changes state and the light should go on and off. The weight of the float in the bucket presses it in until the water level rises.
Posted on Jul 14, 2011
My DEHUMIDIFIER shows check-red light
well you didnt mention model but most times this occurs on dehumidifyers it means the bucket full sensor has tripped , this does not mean that bucket is full, it just means that bucket is either not seated all the way in or maybe the sensor has moved in the bucket and no longer hits the sensor as it should , try reposisioning the bucket and full sensor , ck for looseness
Nov 15, 2014 | Dehumidifiers
Fedders a7dh45b2a powers on fan does not run, all othr lights are on anyone have any suggestions
on this model i suspect that bucket sensor is saying bucket is full if not true then adjust bucket sensor piviot
Oct 10, 2014 | Fedders Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
The Bucket Sensor light is always beeping and the front panel says 01. The machine refuses to work
heatman101
Sep 18, 2011 | Kenmore 54501 Dehumidifier
Comfort-aire model bhd501b unit comes on then goes off-bucket full light flashes- code comes ch-10
I've had to strap several buckets on with bungie cords; they shake some and the bucket full sensor thinks the bucket has been removed.
Jan 05, 2010 | Comfort-Aire Dehumidifiers
GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 19, 2008 | Dehumidifiers
CH1 IS SHOWN AS WELL AS THE BUCKET FULL LIGHT
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
Dec 17, 2007 | LG LD65EL Dehumidifier
Kenmore 54701 Dehumidifier Logo
188 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
