Question about Goodman GMS90703BXA Heater
Gas furnace model # gmb100-4 will not fire up ignitor working clicking sound afterwards but no firing up. Whats wrong
    Genius:
  • 1,015 Answers
If induced draft motor comes on then ignitor tries to light but no flame I would change control board.I've had the same problem on several goodman heaters and all but one required new board. The other one was a bad gas valve but I would try board first. Hope this helps. Thanks
Posted on Nov 07, 2010
Janitrol gmp gas furnace ignitor troubleshooting 125 blink
if it is shutting off abruptly the limit is either wired wrong or set wrong. If the fan comes on and blows the flame out there is a hole in your heat exchanger which can result in fire or carbon monoxide poisoning. Have an experienced tech take a look at it to be safe.
Nov 25, 2017 | Heating & Cooling
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
It does not fire at all times igniter works, I can hear the gas valve when opens, some times it fires for a minute and some times does not fire at all
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 07, 2010 | Heating & Cooling
IM TRYING TO FIGURE OUT WHATS WRONG.I WAS DRIVING AND MY 89 TOYOTA PICKUP 3.0 4X4 QUIT RUNNING.WE FIGURED OUT FIRE WASNT GETTING TO THE PLUGS.WE INSTALLED CAP,ROTOR BUTTON,WIRES,DISTRIBUTER,AND IGNITION...
will try to help.try checking the ignitor assesmbly,with out it your truck will not get fire or low fire,so low you won't catch it. the ignitor gives it an extra boost of fire to ignite the gas in the cylinders. try that,but if it checks bad,used ignitors must match numbers with old onr. try used auto parts online. hope this helps and thank you for choosing fixya.com
Nov 28, 2010 | 1989 Toyota Pickup SR5
I AM WORKING ON A CARRIER 90% FURNACE. IT WILL NOT FIRE UP. IT SHOWS A 34 CODE. THE IGNITOR DOES NOT ENERGIZE FROM THE BOARD. NO POWER COMING FROM THE BOARD. I HERE A CLICK AS IF IT IS TRYING BUT NO...
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 25, 2010 | Heating & Cooling
Gas Furnace is not heating anymore.
the fan you hear come on at a call for heat is most likely just the inducer motor. the click you hear is probably the relay for the hot surface ignitor which should glow red, then in turn ignite the main burners. your going to have to determine if the ignitor is coming on. if it isnt the ignitor is bad and will need to be replaced. if it comes on and than shuts off after a few seconds the ifc board is probably at fault
Apr 09, 2009 | Heating & Cooling
Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Dec 09, 2008 | Heating & Cooling
Furnace will not light
What code is the control board flashing when it tries two or three times? Does it even fire? Does it go straight to fan and lockout?
Goodman U-30 Furnace
observe the sequence of operation. stat calls for heat and sends a signal, to furnace. check for 24 volts to common and white wire at furnace.first the forced draft motor starts and should have 120 volts to the plug it attaches to. after forced draft motor starts the pressure or vacuum switch closes should show no 24 volt when checked across terminals. shortly after the ignitor glows and shortly after click the main gas valve opens and main burners fire. shortly after the indoor fan comes on and hot air blows into the ductwork. follow the chain of events to see what doesnt happen and it is a clue to whats broke. maybe start by switching fan switch on stat to on. if fan comes on you have high and low voltage thereby eliminating the stat power and transformer as a problem. if you can see the ignitor look for it to be cracked . look close dont touch any part of it .it is powered by 120 volts when energized from board. dont forget when you take the door off there is no power to the furnace so be prepared to tape the safety switch closed when you are diagnosing.
Oct 24, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
148 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
