Question about Dirt Devil CE5500 Floor Keeper Upright Wet/Dry Vacuum
Dirt devil en vision
I have a dirt devil upright 12 amp en vision I lost my manual so don't know how to get the power brush upholstery attachment to work,also the side attachments don't seem to have enough suction to clean edges. It works great just on my rug but not able to get attachments to suction properly
  • Anonymous Aug 28, 2008
    do not know how to use the shampoo
  • Anonymous Mar 30, 2014
    it will not pick up
Download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Posted on Jun 24, 2008
Locate model no. at the rear bottom of the vacuum.
Then go to Dirt Devil site: http://www.dirtdevil.com/CustomerService/Manuals/
(this site will not find the manual under the name, just model #).
Posted on Nov 18, 2009
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
Good day, I have a EN Vision Dirt Devil upright, 12 amp, wide 15" nozzle. My vacume is blowing out insead of sucking up the dirt from the carpet. Can you help me? What should I do? Thank you...
It's probably the brush "kicking" the dirt out, rather than it being blown out. This happens if there's a clog in the airflow system somewhere. This could be anywhere from the power head above the brush to the tank where the hose connects.
1. Detach hose at both ends. Drop a coin in one end, lift that end up until coin falls out the other end. If it doesn't, there's a blockage that needs to be cleared. You may be able to do this by using a broom handle to push the clog through. Push the broom handle through the power head end.
2. With the hose detached, check the power head connection for blockages. Drop the coin in and see if it drops through. If not, use a wooden spoon handle, or similar blunt object to push the clog back toward the brush, then pull or vacuum it out.
3. Check the filter and make sure it's clean,
4. Remove the dirt catcher and check bottom of holder right above motor. There's a screen here to prevent debris from getting to the motor. Clear any dirt and debris from it.
Try the vacuum and see it this has helped.
Jan 19, 2011 | Dirt Devil Vacuums
The brush doesn't rotate on the turbo tool. the belt on it isn't broken it just seems really stiff to turn by hand as well
The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
Dirt Devil Vision Turbo Belts
Download the Manual (PDF)
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Where is the belt on the dirt devil vision turbo cant find it
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
Oct 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Replacement of the belt instructions
should be just 2 screws by the beater brush, bottom front of the machine, pop them out and remove brush to remove hairs etc. put new belt in .
Jun 15, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
May 13, 2009 | Vacuums
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil CE5500 Floor Keeper Upright Wet/Dry Vacuum Logo
1,554 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
