Question about JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive
Having trouble with the date and time settings
When I try to set the date and time it never seems to stick. I go back in and it's back to the default. I don't understand why.
The Manual states that the internal clock is ran by the internal lithium battery. It suggests that you plug the cammera into the AC for 24 hours to charge this battery. I'm having the same problem and am plugging it in tonight to see how that goes.
Posted on Sep 20, 2008
  • Jirikisan Sep 21, 2008
    OK, the trick seems to be you need to remove the battery and leave the AC powered in. The minute I did this, the set time function worked.
    OK 3rd method.  There is a v1.12 software for the HD3 that specifically addresses this issue.  More info at the JVC support site: http://support.jvc.com/consumer/custrel/...
    Update is relatively painless, takes about 7 min.
  • 156 Answers
This is because of the internal battery that might have problems... not a big deal just take it to the service centers and you can surely have it checked for cheaper costs
Posted on Jun 16, 2008
Where is OK button when setting date and time
Correct my date and time to update my phone ' Windows ...
www.windowsphone.com/.../correct-your-date-and-time...
Windows PhoneIf you're having trouble installing a Windows Phone update, correct your date and time settings manually.
How to Change the Date in Android ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
Android phones normally pull the date and time from the Internet, but if there's a problem with the signal ... Click the "Settings" button to open the Settings menu.
2013 Models - How to Set the Date and Time on your ...
? 0:52
https://www.youtube.com/watch?v=jTSZwCLSiTk
Dec 4, 2012 - Uploaded by Panasonic Canada Help
In this video we will explain how to Set the Date and Time on your Panasonic Cordless telephone, models KX ...
How to Set the Date and Time on Your iPhone - For Dummies
Dec 26, 2015 | Lands Phones
I am having trouble with Port Forwarding for the Westell 327W Wireless Router.
Hello Michael Yancy,
Seems to be a bit dated... but the AMATEURS that have these ... like them.
Those trying to set them up... Not-so-much
see the videos at:
How to set up your Echolink Port Configuration
Port Forwarding For Noobs Linksys Routers
eHAM.net has the best forum (important)
http://www.eham.net/ehamforum/smf/index.php?topic=76200.5;wap2
May 20, 2017 | Westell Wirespeed VersaLink...
Every time I want to take a picture, I have to set the date or it goes back to 01-01-80. I replaced the (date) battery with CR1220 as instructed and put in the correct date. When I shut it off and turn...
Ah-h-h, January 1, 1980....I remember that day. Whoops, I started to slip away!. Try pressing menu/set twice after you set the date and see if it sticks around this time.
Feb 18, 2011 | Canon PowerShot A400 Digital Camera
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 | Watches
Setting Date And Time
By Settings/Time and Date switch Time zone updating to Manual Only. Now you can set time and date below
May 31, 2009 | Samsung S8300 Ultra Touch platinium-red...
Setting Time & Date
press and hold the menu/disp for or longer until the hq flashes. press the minus button until the time flashes...then press play button. press +/- until the hour is set, then press the ff button and change the minutes, then ff to the date and change accordingly. When finished press play then stop.
Sep 04, 2008 | Olympus VN-2100PC Digital Voice Recorder
Setting time and date
Locate your manual at the link below - it is there and it is free!
http://www.sharp.ca/manuals/
Do a reset (pressing the pictured button) and then reenter current information.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
May 13, 2008 | Sharp EL-2630P Calculator
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Stayce,
in order to change from am to pm and back, while in the '=' mode, depress the ÷ key.
Nov 22, 2007 | Canon MP-11DX Calculator
JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive Logo
226 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
