Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC I'Art AV-56wp74
Our tv is mostly red and blue. It is double focused. The words are doubled in red. I tried converge on auto and that didn't help. Then I tried converge manually and the lines are curved. That didn't help either. Also when I did converge, the + was green.
Is it cost effective to have it fixed?
Thank you,
Mattie
  • 1 more comment
  • thekingdom7 Jun 16, 2008
    My picture is off more to the right side of the screen. I went into the convergence setup and adjusted the picture. Although it helped, it did not solve my problem. I refuse to allow some repair-men to do it for me and drain my pocket for something I can do. How can I fix this problem my self?
  • Matties Jun 21, 2008
    Thanks! I'll try it. I ordered the ICs today!
  • fjrcell Jun 23, 2008
    Hello... It looks like my JVC is doing the same thing as Matties. My picture is "ghosting" with a red tint. All numbers and letters look like they are doubled and are in red. Did I understand correctly? I need to order 2 of the convergence IC's and are they the same part number? I can soldier fairly well. Is this a tough job to do yourself? aand where can I download the instalation instructions. Sorry for all the quesions, I just want to make sure I can do it right the 1st time. Thanks for your help.
  • JVC Master
  • 8,617 Answers
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 15, 2008
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
I have a double picture and the red apears to be
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 07, 2009 | JVC AV-56WP74 56" Rear Projection...
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
I art JVC 46 inche double vision
If you do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
Good Luck.
May 24, 2008 | JVC AV-56WP74 56" Rear Projection...
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence module
That 's actually a very reasonable price for a convergence board replacement in that TV. You can expect elsewhere to be double that or more. Unless you know electronics in TVs I don't advise trying to repair it yourself.
C-Dog
Jan 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 Problem
Yes, one of your convergence IC's have gone bad. They are located on the convergence board inside the tv and there are two of them. They are inexpensive and easy to replace if you know how to solder. Watch out for the JVC booby trap sensor on the dvi input card. Don't run the tv with the back panel off unless you have disconnected the DVI card from the main board. I would even cover the little sensor with black electrical tape. Then it is safe to work on the tv when it's open and on. Well safe for those who know what they are doing.
Jul 29, 2007 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
