Unable to reset monitor to put time in, it just keep showing 88:88 flashing
  • 674 Answers
There should be a button or slide switch to put the Monitor heater in the clock set mode. Once you get it in the clock set mode, use the up and down buttons to set the hour (up) and minutes (down). Let me know what model the heater is and I can tell you definitely how to set the time. nitensheaterservice@earthlink.net
Posted on Nov 08, 2010
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 01, 2012 | Computers & Internet
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
When i unplug the timer then reset a new time schedule and plug timer back into wall my timer sets to 88:88. whats am i doing wrong? this timer worked brilliantly until i reset and plugged it back in.
Open following link to identify timer and read instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Timers go bad for many unprovoked reasons.
Check outlet with circuit analyzer.
This timer has 1 year limited warranty.
Extended warranty: If timer is defective, then buy new one from Target or Lowes, and return defective timer in new package.
To review:
Replace AA battery if this model has a battery carriage. Otherwise timer has internal rechargeable battery.
Press reset button with paper clip for a few seconds.
88:88-88 will flash on screen momentarily, and then 12:00 am will display. Timer is ready for programming.
If 88:88-88 does not roll over into the 12:00 am display, try resetting again.
If timer will not hold new programming, and keeps resetting, then see if reset button is stuck.
If timer does not reset and re-program correctly, then timer has gone bad.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 23, 2011 | Woods Industries 59377 Indoor Digital...
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
My microwave won't turn on
I would try another rest buy unplugging ti for a couple of minute,s then plugging it back in.
If it still fails, the keypad may be failing.
Sometimes this is due to direct spraying of cleaner on the controls, or steam or grease.
In models like this, disassembly and cleaning is required.
We can do that for you if you like.
Feb 10, 2010 | Sharp R-203BW Microwave Oven
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
Sep 19, 2009 | GE Refrigerators
Brother mfc-8860dn, unable to reset maintenance message, after fitting new rollers
TURN THE PRINTER OFF PRESS AND HOLD THE MENU BOTTUM AND TURN ON /KEEP PRESSING UNTIL YOU SEE MAINTENANCE
THEN YOU PRESS 82 FOR DRUM OR 88 FOR THE FUSER OR THE KIT.IT FIX YOUR PROBLEM.
SORRY ABOUT MY ENGLISH.
Jun 24, 2008 | Office Equipment & Supplies
Power reset - Rinnai 1004
the rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
Nov 17, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
