Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Color wheel replacement
Where is the jumper for the color wheel located. i replaced the color wheel and the dark colors are very foggy this may fix my prob.
  • hall88756
    hall88756 Mar 08, 2009
    I have the same problem with a similar TV (Samsung HLP 5063W) - I replaced the color wheel and I'm experiencing poor screen quality (predominantly blues). However, I can not remove that jumper you are talking about because there is a black plastic bracket installed across the area where the little access hole for the jumper is. I do not see how to get that bracket off - have you seen this? I posted this problem today with a picture of the problematic bracket in the TV. I hope you can help - I feel I am so close to finally having a working TV again!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
With the back off of the unit, you are looking at a silver can on the light engine. The is the board where the DLP IC is located. There is a large heat sink right in the middle. Near that heat sink you will find a small square cut out where two pins protrude from the inner bd. There is a small black piece across those two pins, that is the jumper. With a needle nose slide that black jumper off of the two pins. Normally if the color wheel is changed and the jumper not remove the picture is very poor with ugly green and purple negative look.
Posted on Jun 17, 2008
I have a Samsung HRL6167WX/XAP rear projection TV and the TV went out one day when the color wheel exploded. What happened was that the color wheel exploded, then the reapir guy came and replaced that,...
yes , u need to remove this jumper , and the whine would go away , the bulletin is unique for each color wheel , the jumper is very small so just take u time to look for it , is located at the dmd board
May 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Can someone please tell me the DMD part # for a HLR6167WX/XAP?
When you replace the color wheel on certain models you must remove a jumper plug on the DMD board. There is a service bulletin that is usually included with factory replacement color wheels. If the color wheel has a whine to it that means it is probably used and came out of someone else's set. Anyhow the plug can be accessed as I recall without removing the shield of the DMD board. I know this because my first one of those gave me grief, too. Samsung changed wheels on different versions of the same model tv so it gets confusing. You should be ok though after adding/removing the two pin plastic jumper from the DMD board. The only other thing I saw cause a green picture eas the plug that goes from the DMD to the digital board can develop bad connections and can be replaced with a regular DVI type cable. Hope this helps, Russmann.
May 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Bad Color after replacing Color Wheel, removing jumper wire did not fix it
after removing jumer, all is perfect.
jumper is inside an opening abut 3/4 inch under label, remove what looks lie rubber.
Oct 03, 2008 | Samsung HL-P6163W 61" TV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Apr 09, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
182 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
