Question about Whirlpool GD5SHAX Side by Side Refrigerator
Icemaker Ice Stripper Arm
The unit seems to be making ice, but after it produces about 4 containers of ice the stripper arm gets dislocated from one side. This causes the fingers of the stripper to turn sideways and tangle in the fingers of the arm ejector. I have put the stripper back in it place, but it still continues to do this. I would like to replace the stripper arm, but i think there may be something else causing this problem
  • 2 more comments
  • mikedileo Jan 19, 2009
    I've been doing the same thing, adjusting the stripper arm every 30 minutes it seemed like.
    Tried to adjust again today and it broke off.
    Anyone know how to rreplace the stripper arm?
  • library_dean May 21, 2009
    I have a side-by-side Kenmore refrigerator that I purchased in 2002. About every 6 to 9 months the ice stripper pops loose on the right side causing the ice maker to stop. I remove the ice maker from the freezer, warm the stripper with a hair dryer, and pop the stripper back in place. This has gotten to be very frustrating. I expect the L-shaped tab which holds the right side of the stripper to break off at any time. I have found that the stripper can be purchased from RepairClinic.com for about $20 plus shipping. At some point I will probably have to buy a new ice stripper, if not the entire ice maker.
  • Lori carlos
    Lori carlos Dec 03, 2013
    how do u snap it back on. I cant seem to do it and I dont want to break it while trying
  • Lori carlos
    how do u snap it back into place. I cant seem to do it and im afraid inwill break it
  • 25 Answers
Just get a new im son quit n riggin the thing
Posted on Jun 19, 2008
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
How do I replace the Icemaker Ice Stripper Arm on my KitchenAid side-by-side refrig? Cannot see how it attaches on the left side. This white ice stripper part is a little over nine inches long.
Remove the IM assembly from the freezer. Take off the front cover and there will be 3 screws to remove the module. Behind that are 2 screws , loosen them untill you can get the stripper arm out.
Eric
Jun 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
ED22DWXTNoo icemaker
If it won't dump then the cause is most the thermostat. (Key 27 Part# 627985) This part is between the black plastic support. (Key 25 and 20)
It can be a little tricky taking the icemaker apart because once the support comes off the ice stripper and arm can fall off so be careful.
Nov 06, 2008 | Refrigerators
Icemaker makes tons of ice and it spills all over the floor
The icemaker should have a thin metal arm that turns it off when the arm is raised, and on when the arm is lowered. This is so when the tub of ice gets full, the cubes push the arm up, and the icemaker is turned off to keep from making excess ice.
When I had the overflowing ice, I checked my icemaker and found that the arm had fallen off (and thus the icemaker won't know when to stop making ice). I found the arm and stuck it back on, and all was well. It may be a bit tricky, and it might take some ingenuity to keep the arm from falling back off.
I hope this helps!
Sep 29, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore side by side
Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
Jan 08, 2008 | Kenmore 50522 / 50524 Side by Side...
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
Whirlpool GD5SHAX Side by Side Refrigerator Logo
996 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
