My Duo-Therm RV roof-top a/c unit continues to come on and off when the system is turned off. No air blows, just the compressor runs for about a minute then shuts off. About 5 minutes later, it comes back on and does the same thing. Again, let me stress, the system is in the OFF mode.
  • 43,501 Answers
The liquid line solenoid valve is bad and is allowing just a bit of refrigerant through it after it shuts off and the compressor pumps down....this causes the pressure to rise a gain and then the compressor comes on to pump down again...
This will happen even if the system is in the off mode...
the valve will need to be replaced... that requires the system to be evacuated and then recharged...
heatman101
Posted on Nov 07, 2010
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic Duo Therm rv Roof Air Conditioner Model# 59516.531.The fan is blowing and the compressor is kicking on but it is not blowing out cold air. Someone said it must be out of freon. Why would...
These are a closed system.(meaning that there is no fill valves for recharging) But a heating & cooling technician can solder them on and re-charge the system. Only problem there is to get an estimate up front, and compare it to buying a new roof unit which also comes with a new warranty, as well as keep in mind that the freon went somewhere, so there is an obvious leak that will need to be addressed as well. Most times it's wiser and cheaper in long run just to buy a new roof unit.
Are you sure that the compressor is kicking in? Did anyone remove cover on roof and check lines from compressor to see if any cooling is occurring?
These don't often leak, that's why I'm asking. Any idea how old the unit is?
Perhaps in fairly new, it's a warranty issue.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
