Bush hw60-1460d my washing machine has stopped halfway through a cycle and is flashing err2, what do I do to fix it?
jsrock516
  • 5911 Answers
SOURCE: wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Sep 11, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
TheMobilian
  • 8220 Answers
SOURCE: light flashing halfway through cycle
Start with the basics. Do you have the right detergent and the right amount of detergent? It sounds to me like that could be it. Too many clothes or not enough clothes could do it too. These new washers weigh the load and make an attempt to fix problems by stopping. The motor over amps with suds problems. It has to run more cycles to get the water clear. Yeah the machine checks the water. So if you have too much soap or the wrong soap or the soap in the wrong portion of the dispenser that could be causing it and then their could be a clogged pump filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 03, 2010
SOURCE: I have a Premium WD602
Have you cleaned the filter ? it is located at the bottom, right hand side at the front. You can't see it unless you remove the plynth. It simply unscrews so you can clean it.
Mine was also showing F02 and wouldn't complete the cycle. After cleaning the filter it was fine.
Posted on Oct 10, 2010
Hi newbie here with no real knowledge of washing machines I have a Bush a126Q washing machine that just won't work help!!!! The start button an action button flash as shown below in pic. This has been...
Because it doesn't have an LCD screen it has 'flash codes' instead of fault codes.
But,
before you do anything else, turn the machine off & unplug it or switch-off the socket switch.
Leave it for an hour, before plugging-in & switching on again.
Whilst it's turned-off, take out the filter again & see if there is anything stopping the water pump from turning. It is usually located directly behind where the filter is.
Because you've cleaned the filter, it might be enough to re-set the machine.
If it doesn't, you'll need to count the flashes.
There's a short space between a sequence of flashes.
Once you know how many times it's flashing, you google;
Bush A126Q flash codes
That should tell you where the washer thinks it's problem lies.?
Best of luck
Mar 17, 2018 | Washing Machines
Stop halfway hygiene wash 90degree
Do you have power to the unit? Does the display light up?
Nov 28, 2012 | Washing Machines
My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Dec 08, 2010 | Washing Machines
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
I’m happy to help further over the phone at https://www.6ya.com/expert/pat_7f6b46a4565f904d
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
Light flashing halfway through cycle
Apr 03, 2010 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Mar 31, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
Jan 19, 2010 | Haier Washing Machines
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
