Question about Motorola Mobility MD681 Cordless Phone
Motorola MD681 Cordless base is not charging? Any trouble shooting ideas?
How do I do a factory reset?
Hi David Thomas,
Please visit Looking For Help .
Best regards
Suny
Motorola Support
Sep 07, 2015 | Motorola Mobility MD681 Cordless Phone
Retrieve message motorola md681 answering machine deleted
Hello Michele Holliger ,
For further assistance you can contact to US Cordless phones pet Monitor and Baby Monitor department : http://bit.ly/1csbWFE
Best Regards,
Suny
Motorola Support.
May 14, 2013 | Motorola Mobility L702C DECT 6.0 Telephone
Power suply too hot
thats more of an inside problem, you can go to a technician; you can also throw it away and buy a new one.
Dec 26, 2011 | Motorola Mobility MD681 Cordless Phone
Do the black & red wire underneath the speaker phone be connected & wher to
If you are talking about the compartment on the right side of the base of a Motorola M681, then you do not have to connect anything. You can add an optional battery (the same battery pack as for the handset) to keep the phone working for a few hours during a power failure. (If the wires have been pulled loose, than the backup battery might not work. However, I'm not familiar with the wiring for this model.) The handset battery must be properly inserted and charged for that to work.
You also must plug in the AC power cord (to the phone and a good outlet) and the telephone line cord.
I hope this helps.
Dec 16, 2011 | Motorola Mobility MD681 Cordless Phone
The handset is not getting charging and is not able to find the base
1. the charger may be faulty so use another charger.
if this continue check if the charging port is working properly if not replace it with a new one.
Jun 02, 2010 | Motorola Mobility MD681 5.8 GHz Digital...
Master reset codes for Motorola MD61 handsets
Remove the spare battery (if any) and handsets from the base station.
Navigate in the menus to the "base settings". Your screen should say "ringer volume, ringer melody, keypad tone, tone/pulse, ..."
Punch in the reset code (including the stars): **335782
Wait for the phone to restart itself (about 5 seconds).
Re-register all of your handsets.
Dec 15, 2009 | Motorola Mobility MD681 5.8GHz Digital...
Buttons stick, wont let me push them!!
You can try alcohol and a tooth brush, making sure you clean around each button.
If this does not work then, take the face plate off of the phone and clean the keys from the inside.
The screws for the faceplate should be behind the battery.
Hope this helps
Ed
May 04, 2009 | Motorola Mobility MD681 5.8 GHz Digital...
Motorola D210 Cordless Phone
hi i have problem with motorola 210 cordless phone ta base is ok but ta single handset screen shows unregister this why is not working.
Sep 28, 2008 | Lands Phones
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Motorola Mobility MD681 Cordless Phone Logo
Top Motorola Mobility Lands Phones Experts
john h
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
