Question about Tomtom GO 700 GPS Receiver
Wil not charge up
Will work plugged into the cigarette lighter but will not charge up
    Sergeant:
  • 243 Answers
Id suggest going to a local battery store such as batterys plus as they can test any power-cell ever made about. to make sure that your battery was not defective. Also make sure that the car isnt off when trying to charge. Try it through AC power in your home first to charge it. You can also make sure the battery is properly seated.
Posted on Jun 15, 2008
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
Had cell phone and computer plugged into dual cigarette lighter unit and cigarette lighter overheated and quit working - we checked the fuse - it seems fine.Just want the cigarette lighter socket to work...
More than likely overheated the wiring going to the lighter as well and burned it off. If you pull the lighter socket out you should see if it did. Simply solder it back on and be careful not to overload it again.
Jan 29, 2011 | 2000 Oldsmobile Silhouette
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
The cigarette lighter does not work on my 1997 Toyota Camry. Where is the fuse for the lighter?
it wil be located in the fuse box, the fuses should be listed on the box or inside the box and again in your owners manual. If you can not locate this way you will need to pull each fuse till you find the burnt fuse replacing with the same amperage fuse. Cigarette lighters can and do go bad, if you find no burnt fuses the lighter can be bad. This can be checked with any 12 volt plug accessory. Good luck.
Oct 26, 2009 | 1997 Toyota Camry
CIGARETTE LIGHTER WIL NOT CHARGE GPS OR PHONE
Check that the fuse for cig lighter is good. Hope this helps..
Sep 09, 2009 | 2002 Hyundai Accent
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Can not figure out how to charge the Vector start it pro
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
Feb 21, 2009 | JUMP START SYSTEM
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Tomtom GO 700 GPS Receiver Logo
35 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
