Question about Panasonic PT-53WX42 53" Rear Projection Television
Cant get the red to move in the lower right corner
    Sergeant:
  • 252 Answers
You will probably need to replace your convergence chips please watch video I attached for you.
Posted on Nov 08, 2010
My LG 32CS460-UC will not turn on It has a red light flashing in the lower right corner
the psu has failed prob a CCFL fault as it flashes red
the low voltages like 5v is ok
get it serviced by a tv person i think its more too do with the lcd panel
Oct 07, 2014 | LG 32CS460 32" Class HD 720p LCD TV, 60Hz...
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
CANT FIND OUT HOW TO ACTIVATE MY WIRELESS CONNECTION.MY COMP IS HP COMPAQ.PLEASE HELP,IM JUST A NOVICE.
In the lower right corner of the desktop, there should be a little icon that looks like a computer screen with 3 or 4 wavy lines above it. That is the wireless icon, and probably has a red x through it. Right click on this, and select view available wireless networks. Find the one you want, highlight it, and click the connect button at the lower portion of that window.
Mar 16, 2009 | HP Smart Buy Notebook
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Color issues in the lower right corner
Unplug the set overnight and plug back in and turn the set on . If the spot goes away alittle then do this again. Up to three days > if that dosent fix the problem then you have a problem in the deguissing coil curcuit. Probably a cod joint on the thermister or a bad relay , a bad coil . Not a big deal repair. Good luck
Apr 24, 2006 | Sony KV-27S42 27" TV
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
