Question about Hotpoint Ovens
Creda Cordialle fan assisted oven is so noisy what can I do?
  • Hotpoint Master
  • 3,463 Answers
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Posted on Nov 07, 2010
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Hi, the oven is not working in my Creda Collection freestanding cooker. I have had the element tested and proved to be ok. Also the fan does not move. The timer is set to manual. Can you assist?
If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
Feb 17, 2011 | Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Just moved into a rented bungalow - the Creda Cordialle electric fan oven will not turn on - the clocks are all over the place and I do not understand how to set them and to get the oven to work at all -...
Try pressing the "select" button. This should activate the settings menu and use the other two buttons to adjust the time or temperature or anything else tha tappears on the display.
Experiment a little and have patience!
Sep 26, 2010 | Ovens
Hotpoint creda eletrice sc36e oven noisy extractor fan, does it require replacing/ tightning?
With this sort of probelem, it is usual to replace the faulty part, as it usually indicates wear in the bearings of the fan.
Mar 22, 2010 | Ovens
Creda 48902. Using the main oven trips the RCD
If it is a electric fan assisted oven, then it is almost certain to be the oven element that is causing the probrem.
This should be located at trhe rear of the oven compartment, behind a removeable cover.
If it is a conventional oven, then it is prbably, one or both of the oven side elements that is faulty.
Hope this helps.
Dec 19, 2009 | Ovens
Ovens Logo
449 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
