Question about Kenwood KAC-X1R Car Audio Amplifier
Amp is not turning on at all. The capacitor I have hooked up is getting power, it just seems like the amp isn't turning on.
This might sound dumb but check the ground on the amp make sure its getting good connection to the frame
Posted on May 21, 2011
The xxx 3.0 farad capacitor does not seem to have a remote wire terminal...was wondering how to find and hook up the remote wire.
Caps don't need remote wire. Remote wire goes directly from the deck to the amp, as it turns the amp on. Capacitors main function is to store the power from the battery and pass it on to the amp, thus not needing a wire to turn it on.
Feb 20, 2011 | xXx Audio 3.0 Farad Digital Capacitor Dont...
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Power acoustik 5 farad neon digital capacitor
You hook it up in parallel with your amp. You'll see a and - on the clear plastic cover.
Hook a wire from your amp or positive to the capacitor
Hook another wire from your amp - or negative to the - on the capacitor.
That's it, you're done.
If the plastic cover is missing, or painted over, with the neon tubes at the top, and the connector/display end facing you, the right side is the left side is -.
Sep 08, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
My insignia amp wont work
Try removing the capacitor and discharging it with a .5 watt (radio shack) light bulb, and then reconnecting it in the same fashion.(before hooking it back up to the amp place it in line with the capacitor until the cap reads 12v with a multimeter or capacitor display) The capacitor will conduct but not store a charge for the amp if not properly charged before making the amp/capacitor conection. and therefore shut down or not start at all.
Apr 30, 2009 | Insignia 1200W Class D Bridgeable Mono...
Power surge blowing fuses on amp when car is turned on.
the voltage regulator in the alternator or the capacitor is malfunctioning. get a multimeter on the battery when u start the car (before the capacitor) if it reads a large surge (something greater than 14 or 15 volts) then u may need a new amp, if not, then test it on the back end of capacitor to the chassie negative, see if u detect spike there.
Nov 26, 2008 | Car Audio & Video
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Kenwwood amp will not turn on
u need a capacitor and a new battery. the capacitor stores reserve power to power the sub and ur old battery isn't producing enough juice for the amp so get a new one
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
How can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Dec 06, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Won't Turn On--- Positive, Negative touched
gell...it sounds to me like you may have fried the capacitor...try hooking it up without the capacitor in line,and check to make sure the in line fuse on your power lead is ok( usually in theengine bay) and also that the fuse on the amp is ok too.
Sep 04, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-X1R Car Audio Amplifier Logo
62 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
