Question about Whirlpool Ovens
Model #WGE83301 The oven does not work, but the stove top is fine. not sure what it wrong, It is the heating elements?
5 Suggested Answers
  • 27 Answers
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Posted on Nov 01, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: GE P7 Oven 2 burners out on stove top
    Purchased a new stove.
    Posted on Dec 27, 2008
    SOURCE: Top oven will not heat up
    JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
    Posted on Feb 07, 2009
    My oven doesn't turn on but the stove top works fine. It just blinks e0 03
    I would check the heating element assuming this is an electric.
    Jan 28, 2013 | Ovens
    Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
    either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
    Jul 28, 2012 | Hotpoint Ovens
    The inside oven is not heating. The top burners are working fine.
    If this is an electric oven, most likely the oven bake element has burnt out.
    the model and serial number should be behind the bottom drawer,
    most elements are held in with (2) 1/4 inch socket hex head screws.
    Remember to unplug stove or shut off breaker before servicing.
    The element can be slid out usually, then unplugged or remove
    the back cover behind stove and unplug it from the wiring harness.
    I hope this is useful
    Aug 02, 2011 | Tappan Ovens
    Kenmore stove model# 665.92024100 While cooking
    Check and see if the broil element has shorted to ground.
    Bonus
    Apr 13, 2010 | Kenmore Ovens
    Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
    Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
    Mar 01, 2009 | Ovens
    Oven will not heat
    Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
    Plz let me know how you get on.Thanks.
    Jan 03, 2009 | GE JKP15 Electric Single Oven
    Stoves 720EF Top Oven Failed
    there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
    Dec 22, 2008 | Stoves 720EF Electric Double Oven
    WHY WON'T MY OVEN HEAT UP?
    Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
    Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
    Oven and stove top not getting hot.
    The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
    Sep 07, 2007 | Ovens
    Ovens Logo
    74 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
