Question about Poulan Garden
I HAVE A (2375) CHAIN SAW WHEN I START IT THE CHAIN COMES OFF. SERIAL# 98208d100182-1.I PUT A NEW BAR ON IT SAME THING HAPPENES.
    Genius:
  • 1,015 Answers
Do you have your chain properly tightened. I always tighten mine so that you can lift chain at its mid point about enough to slip a nickle under. This is just a rule of thumb. But it works well on my stihl. Hope this helps. Thanks.
Posted on Nov 07, 2010
A brand new chain for chain saw is not cutting hat would be the problem?
A new chain may have to be sharpened to
the correct angles & cutting depth for your
saw
You can do that your self
Get the small tool that goes on the chain
& the proper diameter file, at a saw shop
Best if the chain is clamped into a vise & you
do 3 or 4 teeth, then move it along
You can do it on the bar, but it will be floppy to
do your filing
Chains are somewhat generic when made
Do you have the correct chain for your saw?
Nov 03, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I AM LOOKING FOR PART 2375 LE CHAIN BRAKE PART CAN U HELP ME FIND ONE. I AM LOOKING ONLINE CAN NOT FIND.CAN ANY ONE HELP ME FIND ONE. THIS IS MY EMAIL Kbagdon1@aol.com
PLEASE do not shout. Rules here do not allow us to contact you directly. Without a serial number I can only get you close. My best guess follows:
A Poulan "2375LE Gas Saw Type 2" link below (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
It appears you must purchase the entire clutch cover. See the "Handle, Chassis & Bar Assembly"; item 36; pn 545139903; $18.50.
All Poulan 2375 saws can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 18, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil comes out the cover and doesn t oil bar and chain
remove the bar and clear out the oil passage holes in the bar and if you have oil coming out of the oil port in the saw then you should be okay...hope this helps...
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chain keeps binding up, i get it back on, start running my wild thing and with in 10 seconds it binds up
Try putting a new bar on it. Sometimes during use the grove in the bar gets a kink in it. This will cause the chain not to move like it should. Also, the sprocket at the end of the bar can go bad also causing a malfunction.
Best bet!!!!!! Buy a new bar...
Aug 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
May 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2375 w/18 inch bar keeps throwing the chain
when you put the chain on new did you adjust the tension on the chain.most new chains need to be ran a few minutes to heat them up a little.then you need to readjust chian so it doesn't sag out of the bottem of the bar,also when you adjust the chain you need to push the tip of the bar down so the bar is in the up possition.if you don't the bar will work it's way up and loosen the chain.
Feb 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler
take off cover to the bar, remove chain and bar. spray degreaser or hot soapy water in and around the interior housing. look carefully and you should see a small hole that is where the chain lube comes from. typically all you need is a good cleaning in this area. hope this helps.
Nov 04, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
35 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
