Question about Dell Inspiron 1526 Laptop
I have a dell labtop. Error code 0146 how can I fix it
  • 857 Answers
Error 0146 is a related error with harddrive on a dell laptop.
In most cases when you get this error the harddrive may need a replacement.
If you can still boot up your computer backup your data and try to reinstall the operating system and see if this helps you.
Posted on Nov 07, 2010
Char1ieJ
  • 100 Answers
SOURCE: not going in window xp
The error code indicates that your hard drive is failing. If the laptop is still under warranty, contact Dell for support. If not, I would suggest trying to get it booted one more time and copying everything you want to keep off of it. Then, look for a new 2.5" hard drive on Geeks.com or TigerDirect.com (some place like that). Either way, the hard disk is probably on its last leg. I hope this helps!
Posted on Nov 17, 2008
antiochpc
  • 1314 Answers
SOURCE: dell inspiron 1520 error code 2000-0146
Yes, it is a hard drive issue and there is no fixing it temporarily without losing your data. The best thing to get your data is to get a USB enclosure for the type of drive it is (if it's a sata drive or a pata drive) or get an adapter that's an all in one (for 3.5, 2.5, and SATA). Then you hook your failing drive up to the converter, put it in the usb port of another computer and then it will show up as another drive that you can open and explore.
Posted on May 27, 2009
SOURCE: Error code 2000-0146
its a hard drive error you have a bad sector in the drive its defective. If its still under warranty call dell hardware support with the error code. If not buy a new 2.5" drive they are not to spendy. I just replaced mine with a 250g 7200 and my computer works great now.
Posted on Jul 31, 2009
bschilz
  • 2049 Answers
SOURCE: Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Posted on Dec 05, 2009
Testimonial: "Thank you for your help. I don't know what you mean about the thumbs up; I just logged into my account for the first time today and rated you..."
  • 857 Answers
SOURCE: Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Posted on Mar 12, 2010
Dell inspiron black screen error code 2000-0146
Error 0146 indicates a failed/failing hard drive or bad drive sector.
Basically, this means your hard drive will need to be replaced.
May 01, 2012 | Dell Inspiron Computers & Internet
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
Erroe Code 0146 (Dell Inspiron E1505) MSD Unit 0 DST Log contains previous error. ???
Hi ! Error code is this error code 2000 - 0146??? if that is the error message you have to contact dell technical support to replace the hard drive because that error code mean that the hard drive is already faulty. You can Reinstall the Hard drive as well but it is not guarantee that it will fix the issue. Most of the time dell will send a hard drive replacement for that kind of message if the system is still in warranty it will be free but if not you have to pay for the replacement. Hope this will help you . God Bless!
Apr 18, 2011 | Dell Inspiron E1505 Notebook
Dell error code 0146 error code 2000-0146
I am afraid that this error normally points to a drive failure. You may need to get a new hard disk from Dell.
Dec 10, 2010 | Dell Inspiron 1525 Laptop
Mar 12, 2010 | Dell Inspiron 13 Notebook
When running test on my Dell Vostro 1500, error code 0146 shows
Error 0146 is a failed hard drive or bad drive sector, you have a bad hard drive,
Mar 04, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I have an error code 0146 on my dell laptop that isn't a year old. it should still be under warranty. Should I try and restore the whole system or don't even bother and contact dell and let them fix it?
A 0146 error code is a write error on the hard drive. Normally, this is cause for a hard drive replacement. 800-624-9896 call Dell Tech and get it replaced.
Dec 06, 2009 | Dell Inspiron 6400 Notebook
Not going in window xp
You will have to try and boot from the Operating System CD and Run a Check Disk
from the repair utility chkdsk /r/f/p or try a factory restore on boot Press and hold: Control key + F11
Nov 17, 2008 | Dell Computers & Internet
Dell Inspiron 1526 Laptop Logo
310 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
