Question about Mitsubishi VS-45607 45" Rear Projection Television
VS-45607 When I put the TV on the picture is fine, after about 5 minutes it starts flickering and having horizontal lines running through it. It will continue for about 2-3 hours and then go away on their own. Any suggestions? Thank you.
  • Mitsubishi Master
  • 8,617 Answers
Sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Posted on Jun 15, 2008
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS 45607: 1. TV starts out as B/W when first turned on. After about 30-60 min, the color is restored, although not in the full color spectrum. 2. TV flickers a lot vertically. After about an...
You have a bad video board. If you can find one used it is fairly easy to replace once you get into the TV itself. Your color guns could also be adding to this problem. I am not familiar with this television and its components so I dont know if you can replace one color gun at a time or if once one is shot then all three have to be replaced. That should be a start for you anyway.
Feb 25, 2011 | Mitsubishi VS-45607 45" Rear Projection...
Picture has gone bad on my 70 in Misubishi
My recommendation is have a svc co. look at it. That model was noted for multiple electrolytic caps being bad and also solder joints. As long as the picture was good prior to your problem then I would say it's worth repairing. I worked on the same model for 3hrs to take care of all the problems and preventive maintenance.
Mar 22, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture has horizontal lines that move to middle of screen........
Just got this fixed. The problem is the 21 (yes, 21) main capacitors. It'll only get worse if they aren't replaced. The whole screen'll start jumping, multi-hour "warm up" times until you get a clear picture, maybe not even then... it isn't pretty. Just nip it in the bud now, and more power to you if you tackle it yourself. A good repair shop ought to be able to do this for under $400 if you can't.
Nov 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607 Mitsubishi rear projection TV
Oh good, two people. I was getting weary of attempting to slightly change my answer for all the other people who didn't use the "has the same problem" feature. Anyway, the problem both of you have is not too far gone yet, but will get worse if you let it. It's the main capacitors. Maybe not all 21, but probably at least half of the 21 main caps are shot. All should be replaced at any rate. Any shop worth it's salt ought to be able to do this for you for under $400 if you can't do this yourself.
Oct 31, 2007 | Mitsubishi VS-45607 45" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
