Question about Garmin nuvi 205W GPS Receiver
My nuvi205 lost all the maps - Garmin nuvi 205W GPS Receiver
  • Garmin Master
  • 587 Answers
You lose the maps or they not chosen?
To see if they are still on your unit go to Tools.... Settings....Map.... on bottom of screen press Map Info
make sure there is a checkmark in City Navigator North American NT
Posted on Nov 07, 2010
2 Suggested Answers
  • 1514 Answers
SOURCE: my garmin nuvi205 says no detailed maps found that
Details on solving this problem are at http://www.fixya.com/support/t6394648-no_detailed_maps_found_support_routing
Posted on Dec 13, 2010
Citreon c2 vts rac codereader is po106 p 01/01 map/barc0 ckt range/performance fiited new map sensor still wont start
what does the scan tool show.??
? still P0106, and did you reset it?
did you try to start car with MAP disconnected, some do start in limphome mode. rich a a pig but starts.
did you have key off when you fiddled the MAP connector,
or better pull the battery neg, lug first?
lost power to the mAP, check the power pin.
lost ground to sensor.
lost vacuum to the sensor (clogged paths)
Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector Intermittent open in the reference, ground, or signal wire for the MAP sensor Intermittent short in the reference, ground, or signal wire for the MAP sensor Ground problem due to corrosion causing intermittent signal problem A break in the flexible air intake duct between the MAF and the intake manifold Bad PCM
(do not assume the PCM is bad until you've exhausted all other possibilities)
May 23, 2014 | 2005 Citroen C2
Lost north america map on nuvi1490
Please see this link. We can help with that:
http://www.sharc.net/gps_lost_map.htm
Also connect your unit to the PC and log into your Garmin account and re-downoad the map.
Jul 12, 2013 | Garmin nuvi 1490T GPS Receiver
Update download for tom tom xxl 540s is too big for unit, lost all maps
Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
Hope this information came in handy.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
Lost map
you tom tom should have come with a serial number and an activation code.
Contact TomTom directly and you should be able to download the map through TomTom home...
Also the TomTom home app (if ever synced & registered will have an backup of ownership to the device))
Also the device it came with....
Feb 23, 2010 | Tomtom ONE 3rd Edition GPS
When I plug my Nuvi205 into the car this main screen is fixed and I use any other screens. The icon is of a garmin connecting to a computer. I connected my garmin to my computer and did an update but it's...
You need to use the cable supplied with the unit. If this is not possible, you need to purchase a Garmin power cable from their webiste or your local electronics store.
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
Did I lose my map?
First you will want to empty your recycling bin & clear your temporary internet files before re-downloading the Garmin_RMU_2010B.exe file. Below is the remainder of the fix I received from Garmin support and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the end of setup.exe". For example the end would look like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps. 9a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have any trouble with this fix, or are not comfortable trying it please call our Software Support Department at 1-800-800-1020. Please be at a computer that has high speed internet access as we may need to log on to your computer to resolve the issue. Make sure you have the program extracted using the 7 zip program provided above. Hours of Operation Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
Apr 15, 2009 | Garmin nuvi 205 GPS Receiver
Lost the predownloaded Map
If you delete maps without backing them up, there's nothing you can do, but you can put maps back on by connecting to TomTom Home if they have been saved, otherwise you'll need to download and install new maps here
Nov 19, 2008 | Tomtom ONE 3rd Edition GPS
Lost my icn 520 map cd
Contact (I believe its Garmin for that model). I think you will have to buy another copy of their software. If your maps are more than a year old, they are due for an update anyways.
Jerry G.
Jun 27, 2008 | Navman iCN 520 GPS Receiver
Updated to 2008 maps, now I lost my local roads and town maps
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
