Question about Casio G-Shock GW300CA-1V Wrist Watch
I have a Casio Iluminator Telemundo 30 which has a metal band. I don't have the manual and don't know how to change the time. Please help. Call me at 310-691-4787 Doug
SOURCE: analogic change
Hi Gutto. You can find a solution in this manual: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Posted on Nov 05, 2007
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
escapement
  • 2334 Answers
SOURCE: how to resize (remove links) from metal band on casio wtg900da8v
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 21, 2009
  • 6 Answers
SOURCE: Casio WVA-105H How do you replace the metal band
you may want to use rubber
Posted on Jul 10, 2010
  • 630 Answers
SOURCE: como hago para actualizar la
Positive side faces the rear of the watch.
Posted on Aug 17, 2010
Casio databank 150...how to change from am to pm or 24 hr time sandman334@hotmail.com
Write down the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Aug 26, 2010 | Casio Telememo 150 Luminous Keypad Metal...
Problem with WAVE CEPTOR watch band
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 06, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How to change the time
You can find the instructions at this web site http://www.casio-europe.com/euro/watch/collection/aq-230ga-9dmqyes/ :)
Jun 05, 2009 | Casio Analog Digital 2 Time Silver Metal...
Need maual to set the correct time and everything else
Follow this link:
Rate, please.
Apr 01, 2009 | Casio WVQ140EA 7B Waveceptor Watch/Metal...
Lost manual dont know how to set time
Try this link it is a manual for the Casio telememo 30, Just copy and paste into new window.
Let me know if it helps!
http://www.hbwatches.com/manuals/casio/1253.pdf
Nov 06, 2008 | Watches
Casio G-Shock GW300CA-1V Wrist Watch Logo
169 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
