Question about Canon PowerShot Pro1 Digital Camera
On my PowerShot Pro 1, the telephoto lens only retracts back manually 1/3 of the way. It does fully retract when the camera shuts off. Any help is welcome. IS
    Problem Solver:
  • 6 Answers
This is normal as when the camera is turned on the lens come out to focus. This also hapens with my Fuji S1730.
Posted on Nov 07, 2010
Lens retraction noise in canon powershot pro 1
The lens needs to be dismantled, cleaned and lubricated by a camera specialist, the alternative is a lens that will eventually seize, shutting down the camera.
Apr 08, 2012 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error,restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Jul 03, 2009 | Canon PowerShot A460 Digital Camera
Lens error, restart camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Apr 26, 2009 | Canon PowerShot SX100 IS Digital Camera
Camera got stuck
Hello there,
Mar 12, 2009 | Canon PowerShot S80 Digital Camera
Lens retracts with difficulty
1. Do you have a camera case?
2. Or do you not?
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
Aug 08, 2008 | Canon PowerShot SD600 Digital Camera
Canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
