Question about Emerson Televison & Video
We are having problems with our Emerson HDTV HDMI flat screen 42". We go to turn it on; the picture won't come up and it shows a blue screen. We have tried unplugging the cable from the tv and that didn't work; after unplugging the cable and hooking it back up and we go to scan for channels it didn't work, all it give us is a blue screen and we have gone back and forth with your company and Walmart. We purchased the tv back in June of 2008 with warranty. Can anyone help us with this situation and stop us from having to purchase another tv we like the Emerson products for our home is stocked with Emerson products. Help us please.
    Top Expert:
  • Emerson Master
  • 12,962 Answers
Ir is not cost effective when you can get a new one nowadays real cheap along with a new warranty.
Posted on Apr 09, 2017
  • 77 Answers
SOURCE: Toshiba CF36G40 36" TV (picture snowy)
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try partsore.com. The tuner is the metal can the cable goes into inside the tv.
Posted on May 12, 2007
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
maatmartin7
  • 1229 Answers
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
Posted on Jun 26, 2009
ZorWiz
  • 120 Answers
SOURCE: My digital stream converter box DTX9900 was purchased on 8/7/08
My (otherwise great...) DTX9900 converter box died with these same symptoms. (Units green LED flashes continuously and unit is dead)
Upon inspecting the unit I located a blown electrolytic capacitor on it's power supply board. After replacing the blown capacitor the converter has worked fine. A blown capacitor can be identified visually. The canister's top will be expanded out instead of flat. Just compare all of the caps. Look for any that are not flat on top. Blown caps will usually be discolored. The bad cap in my unit was a 330uf / 16v - 105c value cap. I replaced it with a slightly superior brand 330uf / 25v - 105c cap.
HTH
Posted on Aug 03, 2009
  • 257 Answers
SOURCE: Sony Wega Trinitron HDTV Blue Screen with Sound
It means the TV does not receive signal from the box. Try the follow step to isolate the problem.
Use the same HDMI cable from cable box and hook up to another TV that has HDMI input (if any). If it works fine (picture and sound), HDMI cable no problem. If it does not, problem might come either from the cable box or HDMI. You may have to buy another one. If it still does not, call the cable box or the Best buy guy. Hope it helps.
Posted on Aug 11, 2009
Testimonial: "Swapping cables didn't work so I called the cable company, walked me through resetting the box, which seems to have solved the problem. Thanks."
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
My hdmi cord going from my emerson lcd, to my lcd computer desktop and isnt showing a picture on the tv while im on the computer
Have you checked your settings in the control panel? Also, does your tv have a source that is for pc?
Nov 24, 2012 | Emerson LC320EM9 32 in. LCD HDTV
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
I Have a Samsung flat screen ser# LNS4692DX/XAA that video went out and went to dark blue on all channels,still have good audio but cant even get a menu screen any suggestions?
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On
Do you get Menu screen now or tv shows channels?
If problem still not solved then let me know how old is this tv and any related info about problem like storm or lightning in area that caused this problem in tv. Does tv show picture in dvd playback?
Thanks.
Nov 04, 2010 | Samsung SPN4235 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Toshiba Regza 42" lost all hdmi input
TV was on, screen went black... Stanley cup playoffs double OT continued sound only. TV now just clicks on and off.
Mar 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
